Author Topic: Fuel hangers  (Read 14990 times)
Fuel hangers
« on: April 03 2018, 02:34:57 PM »
Other than missing a harness, anything wrong here?
https://www.highflowfuel.com/i-32555655-quantum-fuel-pumphangerw-sending-unit-for-buick-regal-grand-national-3-8l-1984-1987-255lph-340lph-400-450lph.html
Anyone remember how much Jack's SS hangers were when he sold them?
Re: Fuel hangers
« Reply #1 on: April 03 2018, 03:14:49 PM »
I don't know but for $30 shipped mine is on order. I have a discontinued harness from racetronix to try with it. Maybe my gas gauge will work again.
Re: Fuel hangers
« Reply #2 on: April 03 2018, 04:14:12 PM »
I got the plug-n-play hanger and pump from Jack when he first released it. Think I paid 179.
Re: Fuel hangers
« Reply #3 on: April 03 2018, 04:25:59 PM »
I wonder if it's set up for an analog or digital fuel gauge.
Re: Fuel hangers
« Reply #4 on: April 03 2018, 05:10:29 PM »
I will put a meter on it when it gets here. They sent an email saying I ordered .
Re: Fuel hangers
« Reply #5 on: April 04 2018, 10:25:53 AM »
Anyone use a MAHLE/CLEVITE fuel filter?
Re: Fuel hangers
« Reply #6 on: April 04 2018, 02:46:38 PM »
Never even seen one. I usually add a wix brand one into the cart when I do a rockauto order.
Re: Fuel hangers
« Reply #7 on: April 04 2018, 05:57:41 PM »
Scoob's goin' left and I'm goin' right...no more questions!...https://www.youtube.com/watch?v=YYAjr1DBe9g
Re: Fuel hangers
« Reply #8 on: April 04 2018, 06:07:42 PM »
I throw the cheapass 3 dollar one on from Parts Source once a year. Red and black box...don't remember the name.
Re: Fuel hangers
« Reply #9 on: April 04 2018, 10:45:04 PM »
Today I learned: So unless I am mistaken there are standard electrical nylon 3/8-knockout cable glands being sold as special fuel tolerant bulkhead fittings for about 5x the price...
Re: Fuel hangers
« Reply #10 on: April 05 2018, 01:18:31 PM »
Looks that way to me too. I thought it was odd that it was a fitting just to run a solid wire through it and the 'seal' was just a compression area on the insulation.
   When I did my hangar mods I drilled a hole for a grommet slathered in Yamabond for an 8AWG wire that runs straight to the fuel pump.    Not ideal since fuel can wick up the wire a little, but I don't care.   I didn't feel like driving 20 miles to the machine shop to fire up the lathe and make an actual bulkhead fitting out of a bolt and some UHMW.
It works fine though.
On the ground side, I soldered a ring terminal to the downtube for the pump ground. Then soldered a ring on the very top for the frame ground.
Re: Fuel hangers
« Reply #11 on: April 05 2018, 08:22:46 PM »
I need some very compliant cable at work so I started buying RC "noodle wire" from Tower Hobby. Not cheap but amazing 12Ga -a zillion strands with silicone rubber insulation. It might be a good fit here.
Re: Fuel hangers
« Reply #12 on: April 06 2018, 09:26:43 PM »
Fuel hanger arrived today.
Put a meter on it. Looks like it goes from 20ohms when empty to 120 ohms when full.
Re: Fuel hangers
« Reply #13 on: April 07 2018, 08:35:26 AM »
Steve 2009: "I think it will sit on full a long time"
Spina:
Analog sender: 90 ohms FULL, zero ohms (grounded): EMPTY
Digital sender: 120 ohms FULL, zero ohms (grounded): EMPTY
The resistor wire senders are very inefficient and the accuracy doesn't even exist.
So, if you place a jumper between ground and the center pin of the weatherpack at your gas tank, you should read EMPTY.
Use a 47 ohm resistor in place of that jumper and you should read half a tank (analog).
Use a 56 ohm resistor in place of it for the digital car, and you'll read somewhere around 8 gallons.
You can use an analog sender for the digital car, but when full, the digital gauge will show around 14 gallons instead of "F". As you consume fuel, the digital display becomes more accurate.
You should make it a practice to keep no LESS than half a tank of fuel at any given time - lower than half, the fuel pump runs hot and wears out prematurely. It's the gasoline that keeps the fuel pump cool, and in top operating condition. (corrected)
https://turbobuick.com/threads/fuel-gauge-out-of-whack.431177/
« Last Edit: April 07 2018, 08:50:48 AM by daveismissing »
Re: Fuel hangers
« Reply #14 on: April 07 2018, 09:40:38 AM »
So 380 ohms in parallel with the sender would fix most of the range.
 I don't like the 20 ohms at the other end. I will have to play when I get mine.
