Author Topic: Help with powerlogger readings  (Read 30280 times)
Re: Help with powerlogger readings
« Reply #15 on: February 04 2018, 08:44:41 AM »
That is my first thought as well. Did you check the fuel pressure?
« Reply #16 on: February 04 2018, 08:57:04 AM »
It's gotten to the point I'm telling guys to install an in car fuel pressure gauge.
Offline Robjob
« Reply #17 on: February 04 2018, 11:42:08 AM »
The fuel pump, I will hook up the fuel gauge and take it for a run and find out. I just put 80lb injectors in. The boost is at 8lbs. So. I should be around 51lbs at wide open throttle right? Is there anything else I should look out for. In the frame with the knock at wot the tps was at 2.74 should I be worried about that.
« Last Edit: February 04 2018, 11:46:11 AM by Robjob »
« Reply #18 on: February 04 2018, 11:56:46 AM »
Have you checked the tps at no throttle and wot with eoff/keyon? 2.74 isn't where id want the wot tps reading.
Offline reality
« Reply #19 on: February 04 2018, 12:08:07 PM »
« Reply #20 on: February 04 2018, 01:13:40 PM »
BLM's at idle with the engine warmed up. Steve and I are guessing at the fuel pump...that's why Steve's asking for fuel pressure. Fuel pressure should be no less than 1 for 1 with boost.
Offline Robjob
« Reply #21 on: February 04 2018, 01:29:02 PM »
Ok I’m going to check in about an hour or so and post the results
« Reply #22 on: February 04 2018, 01:44:07 PM »
Static(with vac hose off) +boost = needed fp if the pump is keeping up. Another thing that threw me was the maf gr/sec reading. At wot a stocker should go to 255.and i think an upgrade maf w/translator should go to 255 unless you have some thing more fancy.
« Reply #23 on: February 04 2018, 02:58:44 PM »
You should be worried about knock...period .
« Reply #24 on: February 04 2018, 03:42:53 PM »
The maf will not go to 255 at 7 psi. It takes around 17 psi on a stock set up to reach 255 g/s
The ECM ignores tps IF the ecm has commanded PE which is determined by LV8 which is set by the chip maker.  I would go thru the process of setting it to whatever your chip maker specifies so it will be able to be programmed.
« Reply #25 on: February 04 2018, 03:46:05 PM »
I'm pretty sure I'm getting 255 and I'm thinking I'm only around 14psi. Tt chip and 42lb injectors. Maybe that makes it different.
« Reply #26 on: February 04 2018, 03:50:13 PM »
TT has an automatic lock on at a certain point, that may have something to do with it.
« Reply #27 on: February 04 2018, 04:04:00 PM »
If he had 7.8 psi at 178, then 14 psi would appear to be 240 gps...which sounds about right to me and that should lock into wot on Eric's chip...IF, I am doing the math right...that's a really big IF lol
If the PL file is showing PE ticked on the data page, it should be fueling correctly-again I think
« Reply #28 on: February 04 2018, 06:21:19 PM »
Oh good... you found your way here.  Follow the direction you are given given to the letter - and I am certain it will work out.
« Reply #29 on: February 04 2018, 09:55:14 PM »
Rob, where are you located?  May have someone close to you that may be willing to meet up to help get the base numbers dialed in
