Nasty Wendy Isn't
Fuel tank vent line
Topic: Fuel tank vent line (Read 3610 times)
TurboCajun
Keith Theriot
Turbo Street Modified
PSI: 1
6 Packed
Fuel tank vent line
January 22 2018, 10:19:01 AM »
I will installing new racetronix fuel line, I was wondering what to do with the vent line, do I need to keep it running to the front or can I just run it to the rear of the car, the canister has been removed for years.
Re: Fuel tank vent line
January 22 2018, 10:30:17 AM »
Don't see any reason it cannot go to the rear
TurboCajun
Keith Theriot
PSI: 1
6 Packed
January 22 2018, 01:50:54 PM »
Thanks Steve
earlbrown
PSI: 6
January 22 2018, 04:17:40 PM »
Just make sure to put some sort of filter or screen on the line to keep out bugs and debris.
And maybe a few loops to act as a water trap. Keep in mine as the tank drains, it's going to pull several cubic feet of replacement air. Any moisture on a short line will make it's way into the tank.
Fuel tank vent line
