Author Topic: Individual coils on TR6  (Read 19783 times)
« on: January 21 2018, 08:13:01 AM »
Spent part of the day on Friday with my friend Jack building this setup. The lid of the TR6 was drilled and tapped to secure the coils.
Re: Individual coils on TR6
« Reply #1 on: January 21 2018, 08:17:16 AM »
Clean install...nice work.
« Reply #2 on: January 21 2018, 09:40:09 AM »
Does it work?
« Reply #3 on: January 21 2018, 11:10:33 AM »
Haven't done any WOT tests. Idle seems smoother and more consistent.
« Reply #4 on: January 21 2018, 11:30:26 AM »
Nice. Looks like a pretty nifty setup. Did you make a cardboard template for the mount while you had it apart?
« Reply #5 on: January 21 2018, 01:44:17 PM »
Parts list and template available on request
« Reply #6 on: January 21 2018, 03:08:02 PM »
Cool. Estimated cost of what you put in? Worth it over the stock coil?
« Reply #7 on: January 21 2018, 10:38:57 PM »
Coils are the big ticket item at $50 a piece, CNP kit from Bob $40, wires $70 and boots/plugs for coils $24.
I've trashed two coil packs in the last year.  Bob over drives the TR6 in waste spark mode to get a decent spark at the plug but it's at the expense of the coil pack. If I could have found a way to mount the IGN1A coils, I would've used them.
« Reply #8 on: January 22 2018, 07:02:00 AM »
What vehicle did the coils originally come on? I can be on the hunt at the "recycler".
« Reply #9 on: January 22 2018, 02:31:25 PM »
what wires did you use?
I have my coils bolted to the valve covers.
« Reply #10 on: January 22 2018, 04:59:27 PM »
2005-2018 LS 6.0
« Reply #11 on: January 22 2018, 05:01:14 PM »
I went with Taylor Spiro-pro 8mm. I like the spark plug boots on them. Easy to grab and pull off the plug
« Reply #12 on: January 23 2018, 05:39:39 PM »
How much dwell does Bob run? Those coils will autofire @ high rpm with the wrong dwell! I think anything over 4.5ms.
« Reply #13 on: January 23 2018, 10:14:58 PM »
I have never had a problem with mine been a couple years and I’m not easy on stuff.
My coils were used to got 8 for $100.00 with brackets at the wrecker from a Silverado
« Reply #14 on: January 24 2018, 07:36:58 AM »
How do the brackets for on the Buick VC? Mods to the brackets? Or the bolt right on?
