Author Topic: I think I have a problem was looking for parts and found this....  (Read 27032 times)
Re: I think I have a problem was looking for parts and found this....
« Reply #30 on: April 05 2018, 05:54:56 PM »
Larry...what's the car weigh in at?
« Reply #31 on: April 05 2018, 09:03:26 PM »
I’m forecasting about 2700 lbs.
got some cool guy parts today
« Reply #32 on: April 06 2018, 08:38:06 AM »
I like this project- Mike is right, one forgets how close to the Camaro the styling was.
We also noticed the cowboy boots
« Reply #33 on: April 06 2018, 06:42:14 PM »
Vintage 80s  Boulet  Indian  head boots. Good French Canadian boots!
« Reply #34 on: April 12 2018, 03:39:58 PM »
Got the tank pump and fuel line installed plan on using the stock feed line as my return line.
« Reply #35 on: April 12 2018, 05:43:31 PM »
Nice- you need a new sticker BTW :)
« Reply #36 on: April 13 2018, 08:03:19 AM »
Starting to look good! :cheers:   Are you upgrading the turbo?
« Reply #37 on: April 13 2018, 08:11:28 AM »
My plan is to run what I have that 61mm has worked well.
I might try stepping up to a 66 down the road. But I doubt I will need it.
« Reply #38 on: April 29 2018, 02:19:00 PM »
Cobbled together a 2.5 inch downpipe I have a 3” but it sweeps too close to the  inner fender. I can modify it but would have to vent the waste gate to atmosphere what’s the opinion would this affect my wide band reading it’s after the waste gate.
« Reply #39 on: April 29 2018, 02:24:50 PM »
Your wideband will read fine with the gate dumped. Looks good
« Reply #40 on: April 29 2018, 04:23:33 PM »
Vent it.
« Reply #41 on: April 29 2018, 07:32:28 PM »
Next question how much of a performance gain going from 2.5 to 3” they have a very similar shape.
« Reply #42 on: April 29 2018, 09:25:06 PM »
my guess is that if you are making 600 hp it will be noticeable.  If you are making 500 hp, it will be slightly better
Offline reality
« Reply #43 on: April 30 2018, 09:19:05 AM »
Larry you are the man. Try both and tell us the actual results.
Offline Grumpy
« Reply #44 on: April 30 2018, 11:43:03 AM »
hybrids rock  :rock:
