Author Topic: I think I have a problem was looking for parts and found this....  (Read 67870 times)
« Reply #15 on: December 14 2017, 11:09:37 PM »
Alright what is this or better yet why?
Re: I think I have a problem was looking for parts and found this....
« Reply #16 on: December 15 2017, 08:38:33 AM »
Hop attenuator?
« Reply #17 on: December 15 2017, 10:21:23 AM »
Hmm apparently they are prone to hop so you are probably right.
Sure looks odd it’s a 9” with the stock brackets welded on.
I wonder how effective it is I understand the principle on a leaf spring but it is set to hit the lower control arm.
« Reply #18 on: December 15 2017, 12:39:05 PM »
Looks like outdated old school tech. One good set of shocks should be enough. Maybe the 9” axle tubes threw the suspension geometry off since they are bigger diameter. Might need some control arm relocation to get the suspension working properly.
« Reply #19 on: December 15 2017, 01:03:55 PM »
I'm thinking new adjustable upper and lower control arms and a sway bar to start and some new shocks probably just 2 lol. I rides like a tank set up like this the spool makes it a nightmare in a parking lot even for a wee car....
bright side 3:50 gears
Offline Be4u
« Reply #20 on: December 15 2017, 11:01:24 PM »
That thing looks pretty clean.
Save the bumper fillers!
Move to Canadia!
« Reply #21 on: January 22 2018, 03:02:12 PM »
Well the small block and TH350 are out.
I will have many questions I hate wiring...
« Reply #22 on: January 22 2018, 03:02:57 PM »
« Reply #23 on: February 01 2018, 11:41:43 AM »
Just set it in place to figure out the mounts and kmember.
« Reply #24 on: February 01 2018, 12:52:22 PM »
Nice!
My dad bought a Vega wagon way back with the intention of doing a v8 swap. Mid seventies were a wild time. Keep up the good work.
« Reply #25 on: March 31 2018, 11:20:02 PM »
 My buddy Chris set me up with a partial harness removed a couple redundant things got a lead to power the CCCI and the injectors taped it up still have to tie into the C437 at the computer side.
I hate wiring....
« Reply #26 on: April 04 2018, 07:38:40 PM »
Bet it feels good to have that part done! Read to start bolting stuff together?
« Reply #27 on: April 05 2018, 02:48:48 PM »
It sure is lol.
I had to drop my converter off not enough clearance at the flex-plate. Got my tank back had a sump installed also have an AEM 380lph in-line pump on the way it’s coming together.
« Reply #28 on: April 05 2018, 03:07:29 PM »
Keep at it Larry!
« Reply #29 on: April 05 2018, 03:42:12 PM »
First test and tune is a month away  :O
