Author Topic: Double Pumper Question  (Read 3842 times)
« on: November 20 2017, 11:08:14 AM »
Anyone have to go to a larger return line when using this setup?
Re: Double Pumper Question
« Reply #1 on: November 20 2017, 11:28:41 AM »
And I'd be appreciative if someone can skool me on how the 2nd pump turns on. Been handed what I think is an old skool build...and trying to sort some things out.
« Reply #2 on: November 20 2017, 11:44:22 AM »
Racetronix says a 15 PSI Hobbs switch is best. The one in the link is 15 PSI. Is it adjustable...o r is it set at 15 and that's it. They have a 10 PSI switch...so I assume it's set and that's it.
http://www.racetronix.biz/itemdesc.asp?ic=HPS%2D15&eq=&Tp=
Factory set...but capable of field adjustment. Statements like this are what makes me throw wrenches...
« Last Edit: November 20 2017, 11:51:12 AM by Scoobum »
« Reply #3 on: November 20 2017, 11:46:16 AM »
Now...is there a light somewhere like Julio uses for his alky kits that lets you know when the 2nd pump kicks in.
« Last Edit: November 20 2017, 11:50:37 AM by Scoobum »
« Reply #4 on: November 20 2017, 01:57:44 PM »
I thought you were talking about a carb at first! :icon_lol:
The hobb switch activates it and you don't need to upgrade the return because it turns on after your first pump is almost tapped out.  Well not quite but you know what I mean.
Are you going double?
« Reply #5 on: November 20 2017, 02:02:39 PM »
No...not me. Scroll up and you'll see I'm trying to sort out someone elses TR. Thanks for the info.
« Reply #6 on: November 20 2017, 02:22:03 PM »
If you have a spare regulator and a gauge you should be able to test where it switches
« Reply #7 on: November 20 2017, 03:49:04 PM »
You may see a slight hiccup in the fuel pressure at the moment it kicks on before the regulator grabs it.
« Reply #8 on: November 20 2017, 07:56:33 PM »
Brad way back when Jack first put these kits up for sale I got one of the first few he made up.
The Hobbs is set but you can adjust it a few lbs up or down & my kit included a wire to hook up a light that goes on when the 2nd pump kicks in. You can also switch back & forth to make either pump the primary or secondary but I've never changed them around. I probably should so the second pump could get some run time.
« Reply #9 on: November 20 2017, 08:27:17 PM »
Thanks Dave. If I read this gents e-mail correctly...th e car's been sitting for a long time. Not sure if he has a lite hooked up to it...or not. I gotta call him.
« Reply #10 on: November 20 2017, 09:12:17 PM »
Okay guys, I talked to this gent on the phone and he'll likely need our help. His name is Peter...and the car's been sitting for 17 years. He's gonna join here...keep an eye out for him.
