Author Topic: Sealing head studs  (Read 6169 times)
Offline vl1500
Sealing head studs
« on: November 17 2017, 09:34:30 AM »
What is everyone using to seal head studs in the block to prevent leakage? Thanks....
Re: Sealing head studs
« Reply #1 on: November 17 2017, 09:39:20 AM »
Anything that says antifreeze resistant.
Offline vl1500
« Reply #2 on: November 17 2017, 10:00:55 AM »
Thanks for the reply.... I am trying to decide between the Permatex #2 non harding, Loctite 567, or the Ultra Black and was wondering who had the best results from which.
« Reply #3 on: November 17 2017, 10:04:06 AM »
I just walk in and grab sealer that says antifreeze resistant. Stuff I used on this engine is black...not sure of the brand. Maybe Permatex?
« Reply #4 on: November 17 2017, 10:04:57 AM »
Run a tap through the threads to clean 'em out.
Offline vl1500
« Reply #5 on: November 17 2017, 10:31:02 AM »
Thanks.....
« Reply #6 on: November 17 2017, 10:43:50 AM »
I use the Loctite 567, it has always worked for me so I really didn't need to try anything else.  Can't comment on the Permatex because I've never used it.
Offline 278CIKILLER
« Reply #7 on: November 17 2017, 12:59:05 PM »
The right stuff, you can't go wrong.
Offline 278CIKILLER
« Reply #8 on: November 17 2017, 01:01:13 PM »
But what do i know...
« Reply #9 on: November 17 2017, 01:32:01 PM »
That I have used and it is amazing!
Offline vl1500
« Reply #10 on: November 17 2017, 01:47:34 PM »
« Reply #11 on: November 17 2017, 02:56:48 PM »
JB Weld.
« Reply #12 on: November 17 2017, 03:07:29 PM »
Yamabond.
And a GM seal tab just for good measure since I run MLS head gaskets.
Offline vl1500
« Reply #13 on: November 17 2017, 03:23:23 PM »
Thanks once again guys!!
« Reply #14 on: November 17 2017, 06:47:22 PM »
I've always used this stuff. It doesn't harden so a retorque can happen anytime
