Author Topic: New start-up help  (Read 51778 times)
Re: New start-up help
« Reply #90 on: November 06 2017, 08:55:20 PM »
I would prefer a single wire Denso or Delco unit.  I never was convinced that the three and four wire sensors worked as well as the original sensors.
Also, if it still seems rich..remove the air filter and see if that has any positive effect.
Offline V6DVette
« Reply #91 on: November 06 2017, 09:36:32 PM »
Think it wouild be ok to use a single wire and just tie in to the signal wire of the harness?
'60 C1 with a 3.8 Buick turbo & trans
62 mm throttlebody-009’s/Translator+w/Extender
Trans by Eric @ Dynotech /3200 stall
Mease_exhaust el. w\home made SS 3” DP
Custom made_FMIC,
Heidit's MII IFS w\ tubular upper & lowers
9” Ford 3.50 gears, 4 link W/11”disc & coil overs_allround
« Reply #92 on: November 06 2017, 09:49:27 PM »
I've killed a lot of Bosch O2 sensors!  I put a 3 wire in my low milage car and it's been really good.  Like Steve said, the Denso or Delco is all you need.  I have the Denso in my other car and it works great.
« Reply #93 on: November 06 2017, 09:50:37 PM »
Should plug right into the original purple wire connector
Offline V6DVette
« Reply #94 on: November 06 2017, 09:59:21 PM »
But the original connector isn't there. Harness for the engine came with the four wire. Don't see why I can't splice into the signal wire and leave the four wire plug taped up do you?
Custom made_FMIC,
« Reply #95 on: November 06 2017, 10:09:23 PM »
I never had a four wire sensor that worked quite right.  The three wire Delco sensors worked pretty well but they don't fail and code like the single wire sensors in many cases.  Instead they seem to lose range of voltage swing.
Bosch never lasted long for some reason.
Offline V6DVette
« Reply #96 on: November 06 2017, 10:14:53 PM »
The four wire is from Ford. I think Jag used them too so what do you expect? lol
I'll leave it be for now. Swap it out if all else fails.
Custom made_FMIC,
« Reply #97 on: November 06 2017, 10:18:55 PM »
Yep, I was just trying to get it to a normal state that should work by eliminating the gimmicks...:)
Offline V6DVette
« Reply #98 on: November 06 2017, 10:23:43 PM »
LOL...There's nothing about this car that's normal. But I do agree about the gimmicks.
Custom made_FMIC,
« Reply #99 on: November 06 2017, 10:48:03 PM »
25 years or so ago, we all tried them...don't see them for the most part these days.  I even had a Kenne-Bell intercooler fan shroud
Offline V6DVette
« Reply #100 on: November 06 2017, 10:58:19 PM »
Ya mean that doesn't work?  :icon_lol:
How about the water cooled up pipe?  :rock:
Custom made_FMIC,
« Reply #101 on: November 06 2017, 11:07:16 PM »
someone gave that to me as well, but, I knew that it could not work so I gave it to some kid who thought it was cool
Offline reality
« Reply #102 on: November 07 2017, 12:44:41 AM »
With that pipe and a little ingenuity 1 and 1/2 tenths and 2 mph. on my car. Maybe it wasn't all the pipe tho. And of no use on the street.
« Reply #103 on: November 07 2017, 06:28:08 AM »
Man...you old guys had all the fun.
Offline reality
« Reply #104 on: November 07 2017, 08:11:40 AM »
Meaning what exactly?
