Wot high gear turn the knob on the translator to add.Read the whole document- if it still doesn’t make sense I’ll see what I can do later.
Ron...are you referring to the ECM? So the ECM automatically compensates/adjusts high gear fueling with Bobs chip for temp/humidity changes?
The computer follows a predetermined curve that is programmed into the chip. Just because it can fuel for 512gs doesn’t mean its it’s fueling correctly. Hence the fine tune adjustments. In no way does an extender correct wot fueling - it’s open loop wot
Brad1. Combination of base fuel, wot fuel, and low gear wot fuel. And I think you know that answer to temperature.2. Like pre programmed chips they aren't 100% right
Don’t get me wrong Brad it’s a great setup and it does add fuel to 512g/s. Basically you would be tuning the same parameters just in a different way.
