Author Topic: Rear end oil change  (Read 5873 times)
Re: Rear end oil change
« Reply #15 on: October 21 2017, 02:47:24 PM »
That's kinda the science behind it.
The reason you have to use the additive is to make the oil slicker so the clutches don't bite as hard.  Since synthetic is already slicker a lot of times you don't have to buy the additive.
I can't think of one reason that you'd purposely use a fluid with more vicious drag than you have to.
« Reply #16 on: October 23 2017, 01:01:31 PM »
As I sit here never knowing it ever needed servicing. Lol. The rear end that is. Never dawned on me
