Doors are pretty heavy. I do recommend a helper if you plan on doing with out some kind of support. I've done pins on our suburban but couldn't find the pins for this. I bought a couple different ones for different gm vehicles but none matched up. So I ordered these off rockauto.com . They came in keystone boxes so I'm sure others sell the same thing.
Busted and new door handle. Pop rivet gun in the pic. Also need a drill to get the old rivets out. I drilled the heads off and got the old handle out. Had to use a punch to get the rest of the rivet out. If you do this roll the window up so you don't bust the window with the punch or rivet.
Also found these adjustments for the rattling window. Wife will be so happy it doesn't rattle when rolled half way down. And to be honest so will I.
While it was apart I took the opportunity to try to attach the door panel material back to the door panel. Not sure this worked well but it is better than the material flapping about.
