Author Topic: 7.13 at 99 Solo Run Vid  (Read 3586 times)
« on: October 15 2017, 11:38:29 AM »
Here's the solo run from yesterday.
https://www.youtube.com/watch?v=gOoZOjB7Gyk
Offline 278CIKILLER
Re: 7.13 at 99 Solo Run Vid
« Reply #1 on: October 15 2017, 12:07:51 PM »
Looks killer Brad, nice run.
« Reply #2 on: October 15 2017, 04:48:13 PM »
Looks good.
« Reply #3 on: October 15 2017, 08:04:41 PM »
Ah very nice! :rock:   What was the 60ft on that run?
« Reply #4 on: October 15 2017, 10:15:37 PM »
Time slip is posted on the other thread. Think it's 1.68
« Reply #5 on: October 16 2017, 10:09:53 AM »
The basic premise is this...and I'm almost there. To have the car run 6.9x heads up and bracket racing in any weather condition on 23 PSI. There's little time to spool...so the car will have to short time around 1.62 consistently. Watch the vid...you'll see the rear tires unload. I need to tighten the rear QA1's 1 or 2 more notches...depe nding on track prep. The other issue is this. Erics chip is far too rich in low gear fuel. I had the full 20 percent pulled the whole year...and the low gear 02's checked in around 806-807 on each of the 5 runs on Saturday. Pull them down to 770 or so...and it'll spool faster and get through 1st and 2nd quicker. I'll talk to Eric and have him lower the low gear fuel...and add some high gear fuel...and the chip will be spot on. I MAY swap in steel shim headgaskets to get it to spool quicker. I'm fairly certain it'll go 6.9x consistently in race conditions without going that route. I'm pumped about next season.
« Reply #6 on: October 16 2017, 02:00:58 PM »
Why are you limiting boost? You obviously have the fuel to go with more.
« Reply #7 on: October 16 2017, 03:13:40 PM »
The same reason I run stock junk and a 5.7 chip. Ron...quit laughing.
« Reply #8 on: October 16 2017, 03:38:50 PM »
Attaboy!
