Author Topic: looking for opinions  (Read 10795 times)
« Reply #30 on: September 28 2017, 09:50:40 PM »
Yes 4.56 with a spacer eeeep
Re: looking for opinions
« Reply #31 on: September 28 2017, 09:54:38 PM »
Run some numbers http://www.tciauto.com/tc/racing-calculators/
6000rpm, 3.73, 26" tires with 8% slip is 115mph. 28" tires is 124mph
I think it's going to need something numerically lower.
Rate of acceleration and RPM drop between gears is going to play a huge part in this.
As for the cam, get something real made - not a 20 year old shelf grind.  There has to be so much to be gained with improved lobe designs and valve events.
The cam in my barn motor has a 3012 and 3013 XFI lobe.
« Reply #32 on: September 29 2017, 12:03:29 AM »
Dusty says 3.42 or 3.31 with a 10" lock up will run 10s
Offline reality
« Reply #33 on: September 29 2017, 12:33:29 AM »
COOL. git-r- dun
« Reply #34 on: September 29 2017, 02:11:18 PM »
The thing is even those lobes are at least a decade old.  There is so much to be gained with newer more stable ramp rates these days.
I keep saying that I want to dissect some classic Buick shelf grinds to see where improvement could be made... until that day here is an interesting write up on specing cams:
https://ls1tech.com/forums/generation-iii-internal-engine/1865721-overlap-valve-events-editorial.html
Offline reality
Offline reality
« Reply #36 on: September 29 2017, 10:54:27 PM »
« Reply #37 on: September 29 2017, 11:21:04 PM »
