Author Topic: Tire Pressure Help-Pic Inside  (Read 27225 times)
« on: September 14 2017, 11:06:00 AM »
Here's a pic of the last run I made at Armdrop in June. This is a MT 28x10.5x15 slick mounted on the 7 inch GN rim. I'm aware it should be on an 8 inch rim...but it is what it is. Tire pressure was 10.2. Note the feather edging on the outsides. Shoot me a tire pressure to try and get this to a full contact patch. I have a high end slick tire pressure gauge that reads in tenths.
Re: Tire Pressure Help-Pic Inside
« Reply #1 on: September 14 2017, 11:46:56 AM »
I would add one more pound of pressure.  Pretty sure you are doing short burnouts already.  Other than a wider wheel to square up the tire, I don't know what else to do.  You are not using tubes, are you?
Offline reality
« Reply #2 on: September 14 2017, 01:39:58 PM »
Nothing to add except  that size tire requires a 10 in rim___ 8 inch rim is good for 9 in slick.
http://www.mickeythompsontires.com/strip/et-drag/
Offline reality
« Reply #3 on: September 14 2017, 02:00:25 PM »
« Reply #4 on: September 14 2017, 02:07:15 PM »
He is in the same situation I am in, I too run the same size tire on a 7" rim.  I did think of getting the factory turbine rims widened.  But you have to work with what you got.
Offline reality
« Reply #5 on: September 14 2017, 02:18:30 PM »
Image result for fighting against yourself
« Reply #6 on: September 14 2017, 05:34:20 PM »
Ron...you've seen that track. It's damn near gravel. These MT's I'm using 1 got for 50 bucks a while back...and even there to good for it.
Steve...no tubes. I'll try 1 pound higher and have a look after one run.
Offline reality
« Reply #7 on: September 14 2017, 05:56:27 PM »
Brad i'm not dissing at all or as Jack Webb would say just the facts.
Not ideal, it is what it is.
« Reply #8 on: September 14 2017, 06:00:44 PM »
You're completely correct on rim size...but I'm not wasting my good slicks. If I had a pair of wider rims with a 4 inch backspace I'd use them. I'll likely be parked with the Nostalgia guys. See ya' there!
« Reply #9 on: September 14 2017, 06:10:34 PM »
Brad mine are on 10" wide wheels 12-14psi usually works.
Looks like the asphalt is just shredding them.
« Reply #10 on: September 14 2017, 08:14:28 PM »
May take 2-3, I think the tire is moving around and not running a nice clean straight line on the asphalt.
Offline Tim Hensley
« Reply #11 on: September 16 2017, 03:11:35 AM »
my 28X9 Hoosier was doing the same thing and would not hook.I went to a Aero 8 in with 4 in backspace and tire squared up and it hooks.It is a low cost 8 in wheel that solved my problem and I added air to the tire, about 13 lb if i remember right.and that took a lot of that sway out on the top of the traps.
I was trying to keep cost down and look stock,the chrome look stock at first glance and just weight 18lb
DLS 210-210
Champion irons
Offline Tim Hensley
« Reply #12 on: September 16 2017, 03:14:11 AM »
and they Aero make a 10in wheel too
DLS 210-210
Champion irons
« Reply #13 on: September 16 2017, 10:30:16 AM »
Any pix of said wheel/tire combo?
Offline Tim Hensley
« Reply #14 on: September 16 2017, 05:29:33 PM »
I'm just to dumb to post a pic
DLS 210-210
Champion irons
