Author Topic: Front suspension  (Read 4981 times)
Front suspension
« on: September 04 2017, 12:02:22 PM »
So, I'm reading up on this and did another swim through the charlief1 (RIP) thread.
I don't really want to go with new control arms, too much $$$, and the one recommend over in that thread have a steel bushing and I daily mine so I don't think that is the answer for me.
I found some energy suspension bushings on the rock auto,  http://imagesrv.catalograck.com/imgVD/ENE/17019.pdf  http://www.rockauto.com/en/catalog/buick,1987,regal,3.8l+231cid+v6+turbocharged,1020957,suspension,control+arm+bushing,7532
But it appears one must use the shells already in there.
Also came across these http://www.spohn.net/shop/1978-1987-GM-G-Body/Suspension/Polyurethane-Bushings-Accessories/Polyurethane-Front-Upper-Lower-A-Arm-Bushings.html
And they say they come with the shells  Both about the same $$$
Mine are gone on the pass side by the down pipe and the inside of the tire wears rapidly.
Also looked at these
http://www.globalwest.net/1023.html
They have the grease zerk. Not sure how that is better but probably helps with squeeking and such. also more $$$ but I don't want to do this more than once.
Thought about some taller ball joints. Could lower the front to get it down with the saggy back.
Any thoughts on these or suggestions for others?
Re: Front suspension
« Reply #1 on: September 04 2017, 12:21:33 PM »
Upon more searching I came across these.
http://www.speedwaymotors.com/1978-88-GM-Polyurethane-Upper-Control-Arm-Bushings,35243.html
so I put the number into ebay and came up with these
http://www.ebay.com/itm/1978-88-GM-Polyurethane-Upper-Control-Arm-Bushings-/381899696596?hash=item58eafee9d4:g:QNcAAOSwa~BYYZ6~&vxp=mtr
Save a doll hair on shipping.
I think this is the way I'm leaning. Might consider a taller lower ball joint if someone thinks it a good addition at this time.
« Reply #2 on: September 04 2017, 02:21:14 PM »
If you keep the stock control arms, geometry will stay the same. New springs are cheap. Make up a heat shield for the passenger side to save the new bushings
« Reply #3 on: September 07 2017, 08:31:42 PM »
Even if I use the different length ball joints and/or some offset upper arm shafts?
I can't get onboard with metal bushings on my daily driver. I guess I just need to get some bushings and put em in with the shield.
http://mas-industries.com/online-catalog/
Part#: CSK6218
It sez they help with camber issues. Rock auto has em for <$15 for the side plus shipping($8 or so).
I can make a heat shield.
« Reply #4 on: September 07 2017, 09:19:18 PM »
You won't know if you have a camber issue until you do all of your repairs. If you do new springs camber will change. If you put offset upper control arm pivot shafts you might create a problem. If your bushings are that shot camber will change, replacing just the bushing will probably keep camber close.
« Reply #5 on: September 07 2017, 09:27:04 PM »
Charlie's parts list has the upper control arms about a1/2 inch shorter than stock length. Sure puts the upper ball joint at a bad angle. His parts list is aimed at a lowered road course Gbody. The metal bushings aren't bad at all on the road. Put about 5k miles on them. Just keep them lubed.  The white t handled well but it was an undertaking to get it right. You rode in it in Hillsboro.
« Reply #6 on: September 07 2017, 11:03:11 PM »
The issue with changing control arm length, and I discussed this w/Charlie, caster now becomes an issue. You have to play around to get a good road and turning "feel"
Offline aminga
  • Chicks Dig the Power Bulge
« Reply #7 on: September 11 2017, 11:07:10 AM »
Poly bushings and new ball joints and call it good.  You can box the stock arms some to make them stiffer.
« Reply #8 on: September 11 2017, 11:59:37 AM »
Agreed. Poly bushings and high quality stock ball joints.
