Author Topic: code 42...  (Read 4531 times)
Offline shmed
code 42...
« on: August 26 2017, 09:44:07 AM »
so a couple wires contacted the downpipe.  an melted 2 to be exact an of course blew a fuse...
fixed the wires tied em up so no more contact
replaced fuses,, cci an fp inj.
tried car an It. fired up BUT see light is  on  code 42 is showing...
wideband also appears dead ?
from what I read on the board there pointing at repalcing the ecm,   which is fine but. id hate to wreck my only spare
so any advice where I should start?
thanks
Re: code 42...
« Reply #1 on: August 26 2017, 09:58:13 AM »
Bypass line is open or grounded
EST line is open or grounded
Prom or Calpack not seated properly
Poor connections between ignition module or ECM
Poor routing of EST harness
Faulty or incorrect ignition module
Faulty ECM
I'd bet dollars to donuts you popped the ECM or ignition module...or both. Have spares to try? I'll assume you killed power to the ECM to reset to try and clear the code. You can clear codes on PL as well.
« Last Edit: August 26 2017, 10:03:24 AM by Scoobum »
Offline shmed
Re: code 42...
« Reply #2 on: August 26 2017, 11:13:47 AM »
Hi Brad
Yes reset ecm
tried a different ecm   still code42
dont have a spare type 2 ign only stock type  guess ill give it a try?
Re: code 42...
« Reply #3 on: August 26 2017, 11:43:10 AM »
Throw it on and see what happens.
Re: code 42...
« Reply #4 on: August 26 2017, 11:50:31 AM »
Can you post a pic of the wires you fried? Steve's our wiring guru...and if the module doesn't cure it...then the pic will help to start tracing.
Offline shmed
Re: code 42...
« Reply #5 on: August 26 2017, 01:00:26 PM »
well tried 3   coil pack modules    same thing code42
\tried changing the   esc module  no change
Appears i cant post a pic says error...idk
« Last Edit: August 26 2017, 02:02:38 PM by shmed »
Re: code 42...
« Reply #6 on: August 26 2017, 01:38:13 PM »
I think I would get the meter on those wires you fried and "repaired" and "hit" em  with the ohm meter to make sure they do indeed have the ability to conduct current.
Offline shmed
Re: code 42...
« Reply #7 on: August 26 2017, 02:03:23 PM »
added a pic hope that helps. ..
Re: code 42...
« Reply #8 on: August 26 2017, 04:30:52 PM »
Pretty much what Brad said. Good guide for troubleshootin g
http://www.vortexbuicks-etc.com/code_42.htm
Re: code 42...
« Reply #9 on: August 26 2017, 05:06:39 PM »
Pic is working. Steve...any idea where those wires end up? Follow Steves 'tree'.
Re: code 42...
« Reply #10 on: August 26 2017, 05:10:25 PM »
If those wires are damaged...then I'd repair them and heatshrink them. Maybe they aren't getting any voltage through?
Re: code 42...
« Reply #11 on: August 26 2017, 08:22:26 PM »
Not sure what colors those are. Or if one of his wb?  That link will show them if they are part of the 42
Offline shmed
Re: code 42...
« Reply #12 on: August 27 2017, 08:36:27 PM »
thanks guys  ill have a look tomorrow if I get a chance..
the wires are grey.   an the other is a pinkish with black stripe.   hope that helps
oh this is the large wire system that goes towards the passenger fender
Re: code 42...
« Reply #13 on: August 28 2017, 03:39:24 PM »
not sure on the grey wires.  If they were grey with a red stripe, they would go to the crank and cam sensors as I see the diagram.
you might have to take your meter and check continuity from the splices to the module connector to see what pins they go to
