Author Topic: A/C Hoses  (Read 9597 times)
Offline Recap
A/C Hoses
« on: June 20 2017, 05:17:21 PM »
Wondering if you can get the hoses replaced on the existing hose assemblies? If so what type of hose do you nee to use as I know as place that can crimp them on for me. As always, any help or info much appreciated.
Re: A/C Hoses
« Reply #1 on: June 20 2017, 07:03:38 PM »
yes. All you have to do is cut off the outer crimp shell and remove the old hose.
The only trick is to make sure you 'clock' the new hose so it doesn't twist up into a spiral when you install it.
I bought a 40 ton crimp tool a while back to make some upgraded battery cables.  If I ever get around to repairing my A/C I'm probably going to make a set of braided lines just to minimize the risk of losing my R-12.
Offline Recap
Re: A/C Hoses
« Reply #2 on: June 20 2017, 10:58:54 PM »
Thanks for the reply. Do you know what type of hose I need to use to replace the old hose?
Offline blown1
  • Turbo Street Stock
  • send em all back!
Re: A/C Hoses
« Reply #3 on: June 23 2017, 09:43:08 AM »
now days,  "barrier hose"  is the   hose to use, it has an additional  layer of nylon (or some such material)
 to better  seal   the freon,
it available  at most parts houses,
or  ColdHose.com
Offline Recap
Re: A/C Hoses
« Reply #4 on: June 26 2017, 11:36:47 AM »
Great! Thanks for the info.
