Nasty Wendy Isn't
Turbo Blankets-Advantages?
Pages:
2
Topic: Turbo Blankets-Advantages? (Read 8182 times)
reality
Turbo Street Modified
Boost n00b
Re: Turbo Blankets-Advantages?
Reply #15 on:
June 21 2017, 08:39:51 PM »
COOL What is the criteria going to be?
Scoobum
Reply #16 on:
June 21 2017, 08:54:13 PM »
PL data has me leaving the line at 3000 in 3 seconds. Let's see what it does with the blanket on it.
Shimy87
PSI: 2
Reply #17 on:
June 21 2017, 10:08:49 PM »
Great...someth
ing else I will need
looking forward to your results
Scoobum
Reply #18 on:
July 01 2017, 10:57:27 PM »
Found a post from Patrick Rubio...who's forgotten more about turbos than anyone will ever learn. He says if you can contain heat then it will help with spool up. Keep the blanket away from the feed and center section for air cooling.
reality
Boost n00b
Reply #19 on:
July 01 2017, 11:39:16 PM »
http://www.roadandtrack.com/car-culture/car-accessories/videos/a29999/how-much-a-turbo-blanket-helps/
reality
Boost n00b
Reply #20 on:
July 01 2017, 11:58:31 PM »
Something to consider
Turbo Blanket - Bad Idea?
Starting to read up on these. First red flag I see is one maker recommends not using it for a daily
driver
, saying when you park the car the blanket works so well retaining the heat that you start cooking the
oil
and such and as a result shorten the life of the
turbo
From the website.....
As these Blankets are designed to retain heat within the turbo, it is recommended that the blanket be removed for
vehicle
"Garaging" as retaining the heat without the water/oil circulation may cause long term reduced life for the turbo (this is particularly relevant when used with non-water cooled plain bearing units.
What do you experts think?
Reason I ask is that there is no doubt with the STS it spools quicker when warmed up. From my testing it's about a 400rpm difference. I can
live
with it but if there is something easy with no negative effects I can do to make it more consistent I would like to do it.
Be4u
Reply #21 on:
July 02 2017, 12:57:06 AM »
Soon, put it on right before the burn out, take it off after the run. Easy.
Save the bumper fillers!
Move to Canadia!
aminga
Chicks Dig the Power Bulge
Turbo Street Limited
Reply #22 on:
July 02 2017, 09:06:10 PM »
The real goal is to retain the heat in the exhaust stream. To do that you need to coat the inside of the housing.
Scoobum
Reply #23 on:
September 08 2017, 02:57:29 PM »
Installed. I'll have before and after data in a week or two.
Grumpy
PSI: 4
Reply #24 on:
September 18 2017, 05:11:15 PM »
Does hold the heat. We have one
BUT I was told she needed it by Russ. Melissa brings up the boost to 1 or 2#s then bumps the first light. We have a new class at the drags here where it's an instant green. Bumps the 2nd light an she is ready to go !!
Pages:
2
