4.1 Cam bearings?
Topic: 4.1 Cam bearings? (Read 2854 times)
Forzfed
PSI: 5
Boost n00b
4.1 Cam bearings?
June 01 2017, 04:39:55 PM »
I was looking at my 4.1 and I see that the back cam bearing isn't grooved, still have to check the front one. My roller cam isn't grooved, so I believe my cam bearings need to be or at least the front one. Anyone know what bearings to use?
earlbrown
PSI: 6
Re: 4.1 Cam bearings?
June 02 2017, 06:33:26 AM »
Fire up a Dremel and groove the front journal in the block. Then you can use plain ole 14 bolt bearings with a nongrooved roller cam.
Forzfed
PSI: 5
Boost n00b
June 02 2017, 09:02:18 AM »
That is only needed for the front one, right? The back doesn't need to be grooved?
earlbrown
PSI: 6
June 03 2017, 03:52:35 AM »
Just the front. That's what feeds the DS lifter galley
Forzfed
PSI: 5
Boost n00b
June 03 2017, 04:49:14 PM »
Thanks, Earl! That is what I thought. If it didn't have the groove in the front would oil still get to the DS during idle and lessen on higher rpm? Or no oil at all?
earlbrown
PSI: 6
Reply #5 on:
June 04 2017, 04:36:29 AM »
none at all unless you have a grooved flat tappet cam journal.
Best thing to do is to groove it and be done. The end.
4.1 Cam bearings?
