Spec on Earl's Pistons?
Topic: Spec on Earl's Pistons? (Read 2690 times)
Forzfed
PSI: 5
Boost n00b
June 01 2017, 11:13:33 AM »
Earl, what are the specs on your piston? Pin height, dome and all that fancy stuff?
TexasT
Legend in my own mind
PSI: 1
So, This black car is fast?
Re: Spec on Earl's Pistons?
June 01 2017, 02:31:52 PM »
I'm pretty sure you can order whatever you want. But I'm sure earl will be along to let us know.
Forzfed
PSI: 5
Boost n00b
June 01 2017, 04:36:56 PM »
I was more interested in the cc's of the dome. But I found a PM from him where he says he uses a 22 cc dome.
earlbrown
PSI: 6
June 02 2017, 06:35:14 AM »
Yep, 22cc inverted dome. OD is anywhere between 2.500" and 5.500"
Pin height can be a little tricky depending on the ring pack. 1/16 have a little less room than 1.5's, and a long rod stroker needs oil ring support rails most of the time.
