The Bastard Child Buick Board
Helper spring on the WG?
spent a few hours trueing up the puck and checking, I get a good 1/4 seal all around so that's not the problem any more....took out and same dam thing 19 lbs boost. actuator rod set to 3/16 and then maxed out rjc controller and got 20 lbs with O2 in the 825 area. Tried the low boost pull and between 5-10 lbs its O2s were 815-820. Getting so frustrated that I'm tempted to put stock dp back on and see what happens. Still no call back from Julio but I did also turn up the turn on point and lower the initial...VERY slightly and if I jump on it in 3rd when boost shoots up to 20 I get a small knock blip to about 2 so I don't think messing with alky settings will be wise.Im out of ideas and this bitch is beating me down
Crank the waste-gate tighter.Being a little rich is'nt killing the ability to make boost.
