Author Topic: Wider Bearings?  (Read 2572 times)
Wider Bearings?
« on: May 14 2017, 12:27:57 PM »
Remember way back when we discussed this?  So, what was the consensus?  Is it more advantageous to go with a little wider bearings to help distribute the load?
Re: Wider Bearings?
« Reply #1 on: May 14 2017, 01:16:15 PM »
Think of the engine in my car as a test mule. I beat on it every weekend...with stock width bearings. I can contact Joe for brand and clearances.
Re: Wider Bearings?
« Reply #2 on: May 14 2017, 02:03:42 PM »
they not only increase the load bearing capacity, but they help hold the rod more vertical.
Since drop in wider bearings exist I'll never build an engine without them.
Re: Wider Bearings?
« Reply #3 on: May 14 2017, 04:02:44 PM »
Thanks, Earl!  Do you have a make and part number for a wider bearing for a 4340 crank?
Re: Wider Bearings?
« Reply #4 on: May 14 2017, 06:30:57 PM »
I get them for a 95 park ave.   IF your crank has a large radius, you might have to cone them for clearance.
