Boost-Vacuum issue on Scanmaster
Pages:
2
Topic: Boost-Vacuum issue on Scanmaster (Read 7405 times)
nocooler
Administrator
Re: Boost-Vacuum issue on Scanmaster
Reply #15 on:
April 28 2017, 05:02:04 PM »
A mighty vac and a low resolution air regulator for you compressor would allow you to test it. Just watch it on the powerlogger or scan master
daveismissing
Reply #16 on:
April 28 2017, 07:39:01 PM »
I suspect the common failure mode is that it leaks and thus become inaccurate rather than just being wrong/bad. Anyone have exposure to a few failures?
aminga
Chicks Dig the Power Bulge
Turbo Street Limited
Reply #17 on:
April 29 2017, 10:56:55 AM »
it's a strain gage sensor so it can flake out electronically too. You'll see it like in the output. Most fail by leaking. Apply 20PSI or so and I'll bet you can hear it leaking past the body.
Just a Six?
OK Now who Farted??
PSI: 2
Reply #18 on:
April 29 2017, 11:04:22 AM »
I'm thinking I'll put back the 2 bar to test when the engine is hot & if it reads normal then the 3 bar is bad.
If the 2 bar also reads bad then I have another issue but I hope it's just the MAP sensor.
I only need to cruise & then get into a couple lbs boost to see if it's good or bad.
I'll try to do it this weekend & let you know what happens?
Reply #19 on:
April 29 2017, 04:38:20 PM »
be sure to set the pl to two bar
Just a Six?
OK Now who Farted??
PSI: 2
Reply #20 on:
April 29 2017, 05:44:05 PM »
Good thing you said that Steve as I surely would have overlooked it. Good news is I'm picking up a 3 bar in the morning so hopefully it's an easy diagnosis.
Just a Six?
OK Now who Farted??
PSI: 2
Reply #21 on:
May 17 2017, 08:13:16 PM »
So I borrowed a known good 3 bar & long story short I couldn't get the engine compartment hot enuf to make it go nuts but it's going to be pretty warm here so maybe this weekend I'll know the problem. I wanted to post final results but don't have them yet.
Reply #22 on:
May 18 2017, 05:01:09 PM »
maybe it did not go nuts because that fixed the problem! Be optimistic
Just a Six?
OK Now who Farted??
PSI: 2
Reply #23 on:
May 19 2017, 11:08:50 AM »
I sure hope so Steve, but my testing was messed up from a hose I knocked off by accident.
Long weekend here so if the rain stays away the roads will be wide open.
gusszgs
Turbo Street Modified
PSI: 1
Limited quick brick
Reply #24 on:
May 20 2017, 09:17:32 AM »
Watch out for the boyz in blue.........t
hese long weekends are great revenue generators for the gubment
Jim
1987 T Limited
Pages:
2
