Author Topic: FMIC size  (Read 3517 times)
FMIC size
« on: March 29 2017, 07:25:11 PM »
What would be a better core size for a car with my mods, a 24 x 11 or an 18x11?
Re: FMIC size
« Reply #1 on: March 29 2017, 07:52:23 PM »
Gonna need more info. Intercooler, radiator? Let us know.
Re: FMIC size
« Reply #2 on: March 29 2017, 09:13:43 PM »
Stock radiator, car stays steady at 165 temp. Going to put in a fmic. Looking for advice
Offline 1KWIKSIX
Re: FMIC size
« Reply #3 on: March 29 2017, 09:27:39 PM »
I'd think for a car driven on the street majority of the time the RJC IC-315-XTF would be the winning ticket!
This is the one I'd choose for my Buick if I was going front mount.......
http://rjcracing.com/product/intercoolers/ic-315-xtf/
Re: FMIC size
« Reply #4 on: March 29 2017, 09:42:11 PM »
You won't go any faster with a FMIC. Pull the transmission and have it swapped to a NL and grab a 2800 off the shelf PTC NL convertor. Then post for either a Precision SLIC...or a Precision FMIC.
Re: FMIC size
« Reply #5 on: March 30 2017, 09:56:03 AM »
Thanks guys!!
Re: FMIC size
« Reply #6 on: March 30 2017, 04:39:43 PM »
Thanks guys!!
I hate seeing people piss money away on something that gives them a minimal return. We talked before, and that convertor can't be locked at WOT. One of the locals...and this young man knows how to tune...went 11.01 at 123 on a 1.7x launch on 20 PSI pump gas with a stock stroke 109 and a set of heads. Turbo was a 6131 with an off the shelf 2800 PTC NL convertor. The MPH tells me the convertor was coupling pretty well. An RJC IC would be overkill for your car. A Precision SLIC would work well...as you're spraying alky. You could also grab a Precision FMIC...as you're leaning towrds a front mount. Either could be had fairly cheaply used...as they aren't made anymore...to my knowledge. Your other option is to grab a multidisc Vigilante 2800 LU convertor. I believe they're available in a 5 and 7 disc. Slip rate comes in between 3 to 5 percent when locked...and they can handle it all day.
