Author Topic: Well, that was fun!  (Read 12017 times)
Offline Racer X
    • http://www.hotrodbuick.com
Well, that was fun!
« on: May 28 2006, 07:16:39 PM »
The shaft has about 1/8" of end play in it and the intake blades are all chewed up. Something died in there and took the turbo with it.  :bigeyes;
2008 Charger SRT-8
2009 Challenger R/T
any questions?
Offline Be4u
Well, that was fun!
« Reply #1 on: May 28 2006, 07:59:33 PM »
Damn, what do you think happened?
Save the bumper fillers!
Move to Canadia!
Re: Well, that was fun!
« Reply #2 on: May 28 2006, 08:08:11 PM »
Pssshh!
Childs play.
Now THIS is a chewed up impeller!
http://ihadav8.com/gallery/mscarpics/Dscn00592
Offline Be4u
« Reply #3 on: May 28 2006, 08:12:26 PM »
Quote from: "SuperSix @ Sun May 28, 2006 4:08 pm"
Pssshh!
Childs play.
 :bigeyes;  :bigeyes;  :bigeyes;
Move to Canadia!
Offline Racer X
« Reply #4 on: May 28 2006, 08:42:22 PM »
Pssshh!
Childs play.
I don't know if that's chewed up or chewed OFF!  :rofl;  :bigeyes;
So, I have basically a stock motor, who's turbo should I try now?
2008 Charger SRT-8
2009 Challenger R/T
any questions?
Offline Be4u
Well, that was fun!
« Reply #5 on: May 28 2006, 08:48:48 PM »
Move to Canadia!
Offline Racer X
Well, that was fun!
« Reply #6 on: May 28 2006, 10:09:41 PM »
I *think* I am going to get a 44 unless some you have a good reason why I should not?
2008 Charger SRT-8
2009 Challenger R/T
any questions?
Offline Be4u
Well, that was fun!
« Reply #7 on: May 28 2006, 10:29:44 PM »
I dont disagree.
Move to Canadia!
Well, that was fun!
« Reply #8 on: May 28 2006, 10:42:03 PM »
Looks like somebody took an upper decker in your turbo!
Offline Racer X
« Reply #9 on: May 29 2006, 12:46:43 AM »
:rofl; Yeah.
2008 Charger SRT-8
2009 Challenger R/T
any questions?
Offline Ttype83
« Reply #10 on: May 29 2006, 08:24:55 AM »
I've been looking at the new GT turbos from Limited...I'm in no hurry tho...
Jim Seaton 83 T type
CarbedHotAir Slug
USAF (retired w/22yrs)
Offline Racer X
Well, that was fun!
« Reply #11 on: May 29 2006, 10:44:47 AM »
I have thought about those, but I don't want to the R&D department. I will wait until I hear something.
Have you heard good or bad about these?
2008 Charger SRT-8
2009 Challenger R/T
any questions?
DCEPTCN
  • Guest
Well, that was fun!
« Reply #12 on: May 29 2006, 01:06:42 PM »
Quote from: "Racer X @ Sun May 28, 2006 7:09 pm"
Because it's not enough.  :supz:
Offline Recklessrob
« Reply #13 on: May 29 2006, 06:35:25 PM »
Gregg give us some more info on your setup, and your intentions for it.
S6, did that turbo failure take the motor with it ?
Rob
Offline Be4u
Well, that was fun!
« Reply #14 on: May 29 2006, 08:00:04 PM »
If his motor is mostly stock a 44 would be the way to go I'd think. Tried and tested.
Move to Canadia!
