Author Topic: Battery  (Read 4467 times)
Battery
« on: February 16 2017, 02:38:28 PM »
The Autozone battery in one of my Buicks lost a cell the other day.  Date on the side said 2009 so I got pretty good life out of it.
The current 75s Gold top replacement from AZ is $119 here but it had a bit less capacity as is typical of summer type batteries which is not a bad thing.  But, I thought I would look around and see if I could find a Sears Platinum which is actually the Odyssey battery with a Sears label on it.  Enersys makes them and they have a good rep.  Looks like Sears stopped carrying them last year, so, I kept looking.
I looked at Sam's and saw they listed an AGM battery with the Duracell name on it.  I did not know they even had a car battery, but, research showed it is made by East Penn which generally has a good reputation.  It had a bit more capacity (probably because it is an 34/78 group size) than the AZ battery and AGM can be pretty good in a car that is not started very often.  Sam's had the 34/78 for $129 which was cheaper than most sizes so I bought it.
the 34/78 is about an inch longer than the 75 group size so I took a cut off wheel and cut the spacer off the tray on the radiator side and the battery sat down in the tray perfectly.
So far, so good.  I would have rather had an Energizer battery but it did not come with a rabbit.
Offline Be4u
Re: Battery
« Reply #1 on: February 16 2017, 03:44:49 PM »
What car did you put it in?
Save the bumper fillers!
Move to Canadia!
Re: Battery
« Reply #2 on: February 16 2017, 05:28:19 PM »
AGM for $129 is a good buy! :cheers:
Re: Battery
« Reply #3 on: February 16 2017, 07:22:37 PM »
That is a good deal Steve!  Hope it turns out to be a great value!
Re: Battery
« Reply #4 on: February 16 2017, 08:04:41 PM »
I think East Penn and Johnson Controls make almost all the batteries between them.
Re: Battery
« Reply #5 on: February 16 2017, 08:30:57 PM »
Re: Battery
« Reply #6 on: February 16 2017, 10:07:19 PM »
You know what happens when you put the battery in upside down in the Energizer bunny?
It keep cumming and cumming and cumming....
See what Advance Auto has a good battery listed. They have a $40 or $50 oft cupon code online right now.
Re: Battery
« Reply #7 on: February 16 2017, 11:22:17 PM »
Lol!  rabbits need staying power
Offline Be4u
Re: Battery
« Reply #8 on: February 17 2017, 08:29:47 AM »
Damn Earl, how do you know about all these freebies and coupons?
Move to Canadia!
Re: Battery
« Reply #9 on: February 17 2017, 04:03:44 PM »
Earl believes in using other people's money!
I got mad at Advanced because they did not want to warranty an Optima battery.  too long a story to relate, but, I challenged her to see who could get a district manager on the phone first while the other customers stopped shopping to listen.  In the end, she told someone to give me a battery and get me out of the store.  The guy that took care of me told me she was a bitch and I had just made his day.  :)  He gave me a larger battery than I had brought in and I left smirking.
I did use a coupon and bought two cam sensors for about 60$ each later tho.
Re: Battery
« Reply #10 on: February 17 2017, 05:09:50 PM »
Noice!
And a high five for you. Like the great indoors show commercial.
