Author Topic: Shop Manual  (Read 8025 times)
Re: Shop Manual
« Reply #15 on: February 28 2017, 06:36:34 PM »
you should be able to pick where you want to save it....I picked one of my hard drives
Re: Shop Manual
« Reply #16 on: February 28 2017, 10:10:01 PM »
The linked "file" is an .ISO which is a disk image not a regular file.
You may need to save it and then mount the .ISO which then makes that file behave like another disk.
Re: Shop Manual
« Reply #17 on: February 28 2017, 10:13:09 PM »
If your operating system can't mount the drive "virtual clone drive" is still out there and works. Steve doesn't like it because the logo is a sheep and not  a goat.
Offline poppy1440
Re: Shop Manual
« Reply #18 on: February 28 2017, 11:47:33 PM »
No Mr. Earlbrown it is asking me to insert a blank disk to save the manual to.  But my son installed some program that allowed me to download the manual.  I had the manual on disk but lost it along with my car in the Louisiana floods of August.
I have found another car since but I have been having issue after issue.
I don't think that the entire manual downloaded because I seem to recall the manual going into more detail.   For instance I have been chasing down a code 42 issue and I have gone through the trouble shooting several times on the vortex-buick site.  I have it narrowed down to a CKT423 short,  but I thought I recalled the old manual I had on CD gave full wiring schematics.  I am going to erase the copy I have and attempt to download it again tomorrow.
Thanks
86 gn. Champion irons, roller cam,stock location stretch intercooler, 3" exhaust," DP, scan master, red Armstrong  pump hot wired,  60 lbs injectors, Razors' alky kit, 6265, 6.0 chip, powerlogger, plx-afr, mt 275/50r15 et street
Re: Shop Manual
« Reply #19 on: February 28 2017, 11:53:16 PM »
Theo, this car does not have one of the old Translators with the timing adjustment, does it?  think it was called a Maf-T
Re: Shop Manual
« Reply #20 on: March 01 2017, 02:35:46 AM »
Now an .ISO file is different. That's a disk image file, not an actual file/folder like a .pdf.
for that, you'll have to save the .iso to your hard drive then convert it to actual .pdf files.
« Last Edit: March 01 2017, 12:11:03 PM by earlbrown »
Re: Shop Manual
« Reply #21 on: March 01 2017, 08:38:27 AM »
Now on .ISO file is different. That's a disk image file, not an actual file/folder like a .pdf.
ie: mount the ISO and copy the PDFs to your regular HD
Re: Shop Manual
« Reply #22 on: March 01 2017, 10:38:31 AM »
I had not looked at it in a long time...but, it is indeed an .iso file.  Your son should be able to get it all with no problem and then install it on your hard drive just like the original disk.
Offline poppy1440
Re: Shop Manual
« Reply #23 on: March 01 2017, 03:06:15 PM »
Thanks, yes it is an ISO file.  That's what he told me it was.  He got it installed.
Hi Mr. Steve, it's been a while.  I'm note running a MAF it's a SD2 set-up.  I need to update my signature.
Re: Shop Manual
« Reply #24 on: March 02 2017, 10:41:29 AM »
you are too smart for me, Theo!  I stopped with the SD1...I don't have to think much to use it.
The page with the code 42 shows where the wire goes....from the module to the computer
Glad he got fixed for you.  Sure glad our kids are computer savvy....makes them useful for something!
