Author Topic: I was ass raped  (Read 138846 times)
Offline Recklessrob
Re: I was ass raped
« Reply #30 on: May 31 2006, 12:45:26 PM »
Yes, the noise made by the intercooler hitting the swaybar can be transmitted throught the brackets to the engine block.
Rob
Offline ledzeppac
I was ass raped
« Reply #31 on: May 31 2006, 12:54:47 PM »
Quote from: "DCEPTCN @ Wed May 31, 2006 7:15 am"
Quote from: "ledzeppac @ Tue May 30, 2006 10:06 pm"
hmmm it rests on the sway bar I think but I doubt that would cause any knock....
I was ass raped
« Reply #32 on: May 31 2006, 01:19:55 PM »
they should not touch!!
Offline ledzeppac
I was ass raped
« Reply #33 on: May 31 2006, 02:17:26 PM »
where do I buy the magic non-touching spray?
and I seriously doubt that would cause 8-10 Kr....
DCEPTCN
  • Guest
Re: I was ass raped
« Reply #34 on: May 31 2006, 02:26:35 PM »
Jesus Christ, could somebody go fix his damn car already?
I was ass raped
« Reply #35 on: May 31 2006, 02:36:08 PM »
If your intercooler is hitting the sway bar, then it needs to be repositioned.  This can be accomplished by adjusting or tweaking the brackets and also the hoses.  There is no magic spray.
Offline Racer X
    • http://www.hotrodbuick.com
I was ass raped
« Reply #36 on: May 31 2006, 02:38:07 PM »
I had my IC hitting the sway bar (both stock) and found that one of the brackets had come loose.
2008 Charger SRT-8
2009 Challenger R/T
any questions?
Offline Be4u
I was ass raped
« Reply #37 on: May 31 2006, 03:06:29 PM »
What the fuck is so wrong that makes your IC hit the swaybar? Check your pass side bracket. Tighten it up or bend it up a little.
Also, maybe your turbo is clocked in a downward position letting you IC rest lower with no support? Reclock it?
Save the bumper fillers!
Move to Canadia!
Offline Dragonational
  • Turbo Street Stock
Re: I was ass raped
« Reply #38 on: December 23 2006, 11:27:33 AM »
When is the Knock Happening (if you stated this already sorry) is it at the shifts or all the time?  8 to 10 degrees is Fin high.  now for the stupid questions if you turn the boost down does the knock go away or stay there?  If you havent tryed race gas yet try it with the same boost lvl and see if knock is the same.  If you turn the boost down and you have to turn it way way down then i would say that the knock is false.  If you turn it down and the knock stays then you have bigger fish to fry.  I am sure you probably know all this already but i am just trying to start simple.
i like burnouts they smell good
Offline ledzeppac
I was ass raped
« Reply #39 on: December 23 2006, 07:33:58 PM »
knock ramps ups with boost starting at 4-5... so that would assume its real.  For example:
5lbs 2.3 kr
7lbs 4.5 kr
10lbs 11kr
but if I hold 10lbs for shits and giggles it will jump around 7. 14.12.11.10.15 ...etc...
race gas has been in but that just "richens" it up way to much and wont spool the turbo or even allow rpms to climb.
Ive taken out timing in the T+ and no change.
oh well, ithe knocks been there for 3 years so I'm not really missing anything
Offline 87natty
I was ass raped
« Reply #40 on: December 23 2006, 10:05:07 PM »
Damn, didn't you fly great with 100 octane? List all the shit you've replaced so far. Might be your cam sensor or something.
Offline just plain john
  • Newbie
I was ass raped
« Reply #41 on: August 23 2009, 09:41:48 AM »
Quote from: "87natty @ Tue May 30, 2006 3:22 pm"
Jesus, didn't Lou bend you over to fix it? Cam, timing chain, etc? What else could be wrong? Turn up your furl pressure and swap the chip out. Try an Eric Fisher (Turbo Tweak).
Gimme a call, we'll chill sometime, and drink next to our shitty cars.
            That's Eric Marshall, not Eric Fisher. eric Fisher (Turbofish) is with gbodyparts.
Re: I was ass raped
« Reply #42 on: August 23 2009, 09:50:42 PM »
Glad no one was holding their breath on that one :rofl;
DCEPTCN
  • Guest
Re: I was ass raped
« Reply #43 on: August 24 2009, 04:02:53 PM »
Seriously, huh? Prolly *just* before he hit the the fucking Buy It Now button.
Offline Zap
I was ass raped
« Reply #44 on: August 24 2009, 04:12:18 PM »
When I try to hold my breath it escapes through my fingers. It feels warm though.
You can't get sweet shit outta a sour asshole
