The doors are sagging
Topic: The doors are sagging (Read 2394 times)
TexasT
Legend in my own mind
PSI: 1
So, This black car is fast?
January 05 2017, 09:46:02 AM »
So the bushings are shot. The wind noise is there and i'm sure can be minimized if the door got the door back up where the factory put it. The pass side roller has stopped rolling on the roller and the roller is offset to indicate the bearing is shot. Ive just put pins n bushings in the trucks but never did a roller. I'm kinda wanting these to work like the factory designed em.
So I hit the ebay to look. pins n bushings a plenty but couldn't find a setup like this
http://www.ebay.com/itm/1968-72-GM-A-body-Door-Hinge-Repair-Rebuild-Kit-Pin-Bushings-Roller-Pair-Set-/191826764194?hash=item2ca9c421a2:g:nBUAAOSwoBtW5x
sw&vxp=mtr
For the G body.
I did find whole hinges but didn't really want to go that in depth if I can get away with the bushings n pins.
http://www.ebay.com/itm/78-88-fits-GM-A-G-Door-Hinge-Complete-with-Detent-Roller-All-New-UPPER-LH-/331797118568?hash=item4d40a63e68:g:i1sAAOSwoBtW3d
co&vxp=mtr
These say good for a and G body so I guess Im thinking buy the A body setup and go at it. I got the engine hoist and a nylon strap or two out and "hung" the door, cut the pins and popped the bushings out on the trucks Ive done. This looks the same except closer to the ground.
Anyone have some better advice or thoughts? TIA
Re: The doors are sagging
January 05 2017, 01:09:17 PM »
that is basically the way I did my Regals
motorhead
PSI: 4
January 05 2017, 08:44:17 PM »
My breasts are sagging too.
earlbrown
PSI: 6
January 06 2017, 11:38:13 PM »
Good god... I rebushed mine with a plain ole pin kit off of the HELP! cards.
Since 1998 and over 100K of alcohol and road head and *censored* they still work just fine.
