Author Topic: sender to hard line on top of tank  (Read 4260 times)
« on: December 28 2016, 10:10:17 AM »
http://www.highwaystars.net/hoses-standpipes-to-fuel-hard-lines-set/
I'm guessing these are for the top of the tank. Can anyone confirm before I order?
I have a gas smell in the trunk when I open the deck lid. Thinking the originals have done what they can and need replaced.
TIA
Re: sender to hard line on top of tank
« Reply #1 on: December 28 2016, 10:54:21 AM »
yep
« Reply #2 on: December 28 2016, 11:00:38 AM »
or it could be a rust hole in the tank, leaking sender o-ring, or something equally fun...but, I would guess those lines first.
« Reply #3 on: December 29 2016, 05:04:05 PM »
Apparently the have a $15 set and a preformed set for $25. Is it worth the extra $10 to get the preformed ones?
« Reply #4 on: December 29 2016, 05:12:26 PM »
There's an indention on the top of the tank that will show the routing of the hoses.  A few seconds and some zip ties can 'train' them to lay correctly. (giggity)
Why not just buy a foot of plain ole FI fuel hose in the three sizes and be done with it?  You don't need SAE30R10 for the outside of the tank.
« Reply #5 on: December 29 2016, 10:28:36 PM »
I guess I figure by the time I drive out and buy it I will be ahead just ordering it, and supporting a place with good service and products. Then I will only have to drop the tank once and hopefully fix the prob(if there is one). I'm thinking maybe the feed line has something wrong with it as my o2 drops at wot. Might have a prob with the pressure line or something. It is a fairly new dw200 pump. Maybe I need the dw300 as others are using.
Offline gusszgs
  • Limited quick brick
« Reply #6 on: December 30 2016, 08:41:39 AM »
ha, the one pic the hose is marked.......n ot for FI
Jim
1987 T Limited
« Reply #7 on: December 30 2016, 10:25:48 AM »
That might be the return line. I don't think it sees much pressure.
Offline gusszgs
« Reply #8 on: December 30 2016, 10:36:21 AM »
Ya vapor i believe
Jim
1987 T Limited
« Reply #9 on: January 02 2017, 10:51:31 AM »
When did the nos4gn start charging so much for shipping? It was like $19.75 to ship. Seems like a lot. I guess I'm just used to the free shipping on my eBay orders.
« Reply #10 on: January 02 2017, 11:50:16 AM »
Ouch....f.i. hose is all I have ever used for those....sure comes out cheaper
« Reply #11 on: January 02 2017, 04:59:04 PM »
I'll make a note of the sizes so no one else needs to get the shipping rape.
« Reply #12 on: January 02 2017, 10:16:47 PM »
3/8", 5/16", and a 1/4" as I recall.
Offline aminga
  • Chicks Dig the Power Bulge
« Reply #13 on: January 03 2017, 07:34:18 PM »
I just have FI hose from the parts store on mine.  Cost about $10.
« Reply #14 on: January 04 2017, 05:43:11 PM »
Wow. That is steep for something that could be mailed First Class. Or at least Flat Rate.
