Author Topic: upgrade opinion  (Read 5015 times)
upgrade opinion
« on: October 22 2016, 10:28:54 AM »
Trying to descide on next upgrade this winter. Which will give best performance gain, 3 inch DP, roller rockers, or larger intercooler... ...or something else, sig below show current equipment. The 3 things I listed are all currently stock.
Thanks for any wisdom!!
Re: upgrade opinion
« Reply #1 on: October 22 2016, 12:25:24 PM »
what are you trying to accomplish? Faster eighth/quarter time?
For my money it would be a bigger turbo but the larger intercooler might be good too. A lot of people like a nifty new down pipe.
Might be well spent on some sticky tires for the track. Or just some track visits to do some wot tuning.
Re: upgrade opinion
« Reply #2 on: October 22 2016, 01:29:24 PM »
Nitrous.
Offline 1 RARE T
Re: upgrade opinion
« Reply #3 on: October 23 2016, 08:52:03 AM »
Used downpipe and wide band to maximize what you have.  :powersix:
Offline Old Buzzard
  • Older than Woods!
Re: upgrade opinion
« Reply #4 on: October 23 2016, 09:55:22 AM »
^^^^^^^ :cool;
Chuck
Injector inspector
Drag racing/hot rodding since 1955
USAF 67th Recon, Yokota AFB, Japan. 6594th Test Sqdn, Spfld, MA. The guys that brought you the Cuban missile fiasco in living b&w!
1960-1964
Offline bescurred
Re: upgrade opinion
« Reply #5 on: October 23 2016, 10:52:24 AM »
Deff get a used dp, They're cheap and it'll open up that turbo!
Offline v6sleeper
  • G-body guru
Re: upgrade opinion
« Reply #6 on: October 27 2016, 06:19:03 PM »
1st- get rid of the stock dp and elbow
2nd- a better quality converter
3rd- a good tune and turn up the boost
and if your looking for better then high 11s dutt neck the slic.
87 GN- t-netics hpc,custom 3" dp, champion irons,stage 2 trans ,3021 9.5nl,poston headers ,Atr liquid intercooled, Hemco r plenum
87 Turbo T-  Borg warner,aluminum R-heads,husek trans,E85 Gn-ecu td 1.65 ptc 9.5nl
70 sport wagon 455 stage 1,Gessler alum heads
82 olds wagon Lc2 powered-sold
