Author Topic: 2016 Ford vs Buick  (Read 7914 times)
Re: 2016 Ford vs Buick
« Reply #15 on: October 13 2016, 07:58:29 PM »
Beast mode!
« Reply #16 on: October 13 2016, 08:06:12 PM »
Go get em!
« Reply #17 on: October 15 2016, 07:36:29 AM »
Having trouble with the TR6 again. Base tune at 20PSI was 115 thru the traps. Working with a fella named Jack Laswell. He's a really nice guy and helpful.
« Reply #18 on: October 15 2016, 09:50:19 AM »
Hooking good?
60'?
Cars lookin sweeeet!
« Reply #19 on: October 15 2016, 12:23:59 PM »
Jason. What height back tire do you run?
« Reply #20 on: October 15 2016, 01:18:26 PM »
More problems. Cam sensor reluctor wheel snapped the tab off. Found another one and got it installed. Just FYI, no two cam sensor caps have the same timing set even if you just swap out the caps. So check the cam sensor phasing after changing caps.
One cool thing is that the Andrade racing team parked next to me.
« Reply #21 on: October 15 2016, 01:41:40 PM »
Rich, I have 28x9 radial slicks on the rear.
« Reply #22 on: October 15 2016, 01:44:09 PM »
The Andrade crew and my little old Buick in the background
« Reply #23 on: October 15 2016, 06:06:56 PM »
That's pretty cool. He is the only one from that show is want to meet.
So the cam sensor was giving problems? Now the tr6 giving full spark?
I guess that Mr Laswell is a pretty sharp fella.
« Reply #24 on: October 16 2016, 09:13:54 AM »
Made it back last night around 11 PM. Had a great time with the Dallas-Fort Worth guys.
William showed up on Friday night and ended up braking one of his u-joints. He had to work Saturday and couldn't come back.
Of course the ford guys won the event. We just don't have a lot of guys running in the 10's and that where they killed us.  No worries, it was all in good fun.
I didn't think I would have as many gremlins as I did, but it is a buick. The TR6 reared its head with the cam sensor code but it turned out to be actual. The little tab on the cam sensor reluctor wheel had snapped off. One of the Botkol brothers had a spare cam sensor with him and we swapped out the wheel.  Then the code came back and found the screw for the reluctor wheel had backed out.  Got some lock tite and then that solved that.  Then the phasing was out on the sensor.   That's why I posted about the cam sensor caps not having the same setting even if just replacing the caps. From a setting at 25 degrees with one cap, to almost 33 degrees with another stock cap.  Next thing was building boost at the line and not pushing through the lights. Then I noticed the alky wasn't spraying. It goes on and on.  Also had one run with the tranny not wanting shift.  Also had the SD2 dump the tune and then it had some crazy numbers in some of the cells. Always check your BLM grid before making a hit.  Lots of work to do still
I am happy with the mph. TC was locking at 90 mph. 116.59 ain't too shabby at the traps.  Car consistently picked up over 30 mph from the 1/8 thru the 1/4 mile traps and that's without any alky spraying.
Brad, so you can figure some slip percentages on the converter.
116.59 mph
28x9 MT radial slick
5095 rpm at the traps
3.42 gear
I kept the tune pretty rich at 10.5. At least I know the fuel system can handle it without alky
« Last Edit: October 16 2016, 10:10:12 AM by good2win22 »
« Reply #25 on: October 16 2016, 10:35:56 AM »
Glad u had fun!! Even with issues its still a blast. How can u tell when the convertor locks?
« Reply #26 on: October 16 2016, 11:49:35 AM »
First question is about the short time and your low speed in the 1/8th.
Were you blowing the tires away thru the 1/8th or was it accelerating so slowly due to being way rich?
You can email Brad for a slip number...I calculate very badly in this case!
« Last Edit: October 16 2016, 03:33:22 PM by Steve Wood »
« Reply #27 on: October 16 2016, 12:12:31 PM »
Is that the converter from Jake?
« Reply #28 on: October 16 2016, 02:09:04 PM »
You can email Brad for a slip number...I calculate 20%
Kept pushing thru the brakes at the line.  Saw a slight bit of KR at the shifts so I thru some more fuel at those points not realizing that the alky wasn't spraying. Unless I get a standard actuator for an s cover, I'm stuck at this level of boost.  Actuator is as long as I can safely extend it and the controller is backed out completely. I have a standard actuator, just need to fab up a way to mount it to the s cover.
I ran the numbers on the Wallace calculator and it came up with 5.916%. Am I doing something wrong?  Tire cir. is 87.8
Yes, pig rich.  That time slip posted above is the fastest mph pass and it was the last pass of the event. I didn't go wot until the shift into 3rd and I reached over and hit the test button on the alky controller. Still a work in progress
« Last Edit: October 16 2016, 02:36:29 PM by good2win22 »
« Reply #29 on: October 16 2016, 02:09:34 PM »
Yep it's from Jake.
