Author Topic: Garage Clean Out  (Read 3859 times)
Garage Clean Out
« on: October 10 2016, 10:05:34 PM »
*Please read the ad*
**We ONLY have the parts listed below**
***Need something specific? Call 1-800-230-3030***
****To convert CDN to US use http://xe.com ****
Contact me here via PM or email at 23ADeathTech (at) gmail (dot) com
1. All prices are in CAN plus shipping, and PayPal is a 3% surcharge (or send payment as a gift);
2. I only charge actual shipping charges (have a scale and measuring tape) from Ottawa, Ontario Canada;
3. I will not separate parts, but I will combine them as a package deal;
4. All parts are used unless otherwise indicated; and
5. All parts are sold as-is, with no warranty expressed or implied.
Hi-Res Pics:
https://drive.google.com/folderview?id=0Bxz5jQ7Hp48qZnVDNHYwUEVlbG8&usp=sharing
https://drive.google.com/folderview?id=0Bxz5jQ7Hp48qWnNxY2tVOWxlaWM&usp=sharing
LS1/LS2/LS6/LSX Parts:
1. Comp Cam – Hyd Roller, 3-bolt - 226*/230* .605"/.608" 113+3 ground on LXL/LXL lobes, micro-polished at factory - BNIB - $460
2. CamMotion Cam – Hyd Roller, 3-bolt - 228*/234* .627”/.612” 112+3 - BNIB - $590
3. 2007 LS2 Cam – Stock, 1-bolt - $150
4. 2002 LS1 Cam – Stock, 3-bolt -$75
5. 2007 LS6 Valvesprings – Yellow - $30
6. Brian Tooley Racing (BTR) – Slow Leakdown Rate Roller Lifters - BNIB - $250
Trailblazer SS Stock Parts:
1. Air intake assembly w/MAF (has ~3000 miles on it, slight damage to screen) - $150
2. Fan and shroud - $60
3. Intake manifold w/rails and injectors (100K miles), bolts, and gaskets (no damage) - $375
4. Intake manifold w/rails and injectors (~3000 miles) and one gasket (damage to engine cover mount -cosmetic only, and one nipple at the front) - $375
5. Airbox lid (cutaway and insulated) and shroud insert - $30
6. Air intake adapter (GM P/N 25171042) - BNIB - $10
7. Motor mounts (including brackets/block adapters) - $20
8. Torque Converter (PN: TWBX 2423, ~1800rpm stall behind LS2) - $60
Trailblazer SS Non-stock Parts:
1. 3" catless Y-pipe - $375
2. House of Boost (HOB) V1 cold side kit (works with stock mechanical fan shroud) - $200
3. Custom aluminum air intake box for 4" short ram intake - $60
4. Ported stock throttlebody - $200
5. Racestar Industries –Chrome Truckstar 93 – (4) 17x9.5” w/325/45R17 M&H Racemasters - $2800
78-88 G-body Parts:
1. Koni Front Drag Shocks (G-body) – 80 1958 SPA1 – $150 http://www.koniracing.com/SPA1.cfm
2. Factory front brakes (rotors, bearings, calipers, dust shields, etc) - $100
3. South Side Machine (SSM) Rear lift bars/lower control arms – $50
4. Stock Front Grand National/T-type Springs - $50
Camaro/Firebird/Trans Am/93-02 F-body Parts:
1. Stock '02 LS1 Camaro air intake lid - $5
4. '00-'02 MAC S/S Cat-deletes w/WBO2 bung and new FelPro gaskets - $200
5. Stock LS1 MAF w/large honeycomb screen - $50
8. Torque Converter (PN: TMAX B85, ~1700rpm stall behind LS1) - $50
Misc:
1. Ford Taurus electric fan - $25
