Nasty Wendy Isn't
starts an dies
2
3
Topic: starts an dies (Read 11827 times)
shmed
Turbo Street Limited
starts an dies
October 09 2016, 06:39:29 PM »
ok so we got the new motor in still a 109,
wired it up
go to start it an it fires after a bit of cranking an dies immediately ??
heres whats been hacked out of it
ac , heater box, wiper motor, cruise control, charcoal canister, power master. an the temp sensor on the top of the intake it broke off so not wired up.. think thats all i see missing..
so far we tried a new battery, coil pack an module, crank sensor. added a ground from block to frame, cleaned an tightend grounds at back of head.
all the sensor reading look ok i mean for just key on type stuff.
any ideas
thanks guys
Scoobum
Re: starts an dies
October 09 2016, 07:16:30 PM »
When something like this rears it's ugly head, I go straight to Steves site.
shmed
Re: starts an dies
October 09 2016, 08:02:30 PM »
yes thanks brad I've been on the site tried what he has written nothing thus far..
earlbrown
PSI: 6
Re: starts an dies
October 09 2016, 08:43:06 PM »
Does it fire up and die every time, or did it bust off once and that was it?
TexasT
Legend in my own mind
PSI: 1
So, This black car is fast?
Re: starts an dies
October 09 2016, 08:56:03 PM »
Fuel pressure?
Pump priming with the key turn?
daveismissing
Re: starts an dies
Reply #5 on:
October 09 2016, 10:24:06 PM »
I get fuzzy on this~ but the two feeds to the fuel pump both come up - inc the cct that senses oil pressure?
Scoobum
Re: starts an dies
Reply #6 on:
October 10 2016, 05:49:08 AM »
I'd be looking for proper fuel pressure at the fuel rail. If that checked out...then I'd go through Steve's 'no start' tree.
shmed
Re: starts an dies
Reply #7 on:
October 10 2016, 09:51:00 AM »
Earl yes it fires an then dies every time,
texas yes can hear fuel pump when key is turned on i believe the gauge reads 20 then with another turn of the key it hits 38
I'm curious if one of the removed items maybe be causing this?
Scoobum
Re: starts an dies
Reply #8 on:
October 10 2016, 10:10:00 AM »
Spark?
Injector pulse?
Just a Six?
OK Now who Farted??
PSI: 2
Re: starts an dies
Reply #9 on:
October 10 2016, 10:26:48 AM »
Temp sensor? What happens when that's not working? I forget how important it is?
As the car fires up for a second does the fuel pressure stay at 38?
I've had the pump hold key on & also pressure jump up for a second but then die when engine fired years ago.
The 2" rubber fuel line on the pump cracked open a bit but that's probably pretty rare?
shmed
Re: starts an dies
Reply #10 on:
October 10 2016, 10:52:39 AM »
brad yes spark an ink pulse
dave im not sure i thought that may be the problem..
i unplugged the maf an the car fired up an ran no problem. strange to me but hopefully its all it was,,,, ill post back with an update...
saturdays is race day if we can get the car off the stands....
shmed
Re: starts an dies
Reply #11 on:
October 10 2016, 12:10:41 PM »
well so much for the excitement....
changed out the maf with my spare.. same problem starts an dies.. unplug maf fires right up???
earlbrown
PSI: 6
Re: starts an dies
Reply #12 on:
October 10 2016, 03:47:13 PM »
Are you running a translator? If so look inside the plug and see if a pen is bent.
Have you done the KOEO MAF test to see if the computer is making up numbers or if the MAF is actually reporting to the ECM?
Old Buzzard
Bone Stock
Older than Woods!
Re: starts an dies
Reply #13 on:
October 10 2016, 03:50:28 PM »
" an the temp sensor on the top of the intake it broke off so not wired up.."
That sensor is the overtemp to turn on the fan, if the temp goes over about 225*.
The canister.. Did you plug the hose off? If so, that's the tank vent. Pull the cap, it starts and stays running?
Chuck
Injector inspector
Drag racing/hot rodding since 1955
USAF 67th Recon, Yokota AFB, Japan. 6594th Test Sqdn, Spfld, MA. The guys that brought you the Cuban missile fiasco in living b&w!
1960-1964
shmed
Re: starts an dies
Reply #14 on:
October 10 2016, 04:04:51 PM »
earl what is the koef test? i did try key on engine off an af was at 4 then full throttle still 4 is this what you mean?
no translator stock maf
old buzzard your are correct not wired up the canister isn't there or the electrical gizmo on top i didn't plug the lines there still sitting here open ended.
2
3
starts an dies
