Is the 49 still on it or the 6262? Sorry I can't keep up
Any set of good dual springs should be adequate...
Strange that Comp sells a profile that they cannot provide a spring for.
Jason, if you haven't done so already...cont act Bison. Just my 2 cents...but with the lengths you went to, I would have had him grind a custom cam for that build. I ran a 204/214 cam in that .030 over block I tossed a couple years back when I cracked a second cylinder. I had a 231 standard bore laying around I went with. I consulted with Steve for a cam choice...and we went with a CC's 212/212 flat tappet with GM NOS lifters. Car has run its quickest ET and fastest MPH with that off the shelf cam. Norbs went 134 MPH with a 210/210 and home brew heads and I believe Grumpy used a 212/212 for his 9 second run with Champion irons...and I'm betting Russ warmed them over a tad.
