The Bastard Child Buick Board
intake gasket
Topic: intake gasket (Read 3177 times)
Shimy87
PSI: 2
intake gasket
September 14 2016, 07:57:38 PM »
Can the intake gasket be re-used? I have an oil leak down the back side of the block. Pretty sure I must not have put enough black rtv down and now the prick leaks
Scoobum
Re: intake gasket
September 14 2016, 08:05:44 PM »
Nope
earlbrown
PSI: 6
Re: intake gasket
September 14 2016, 10:35:05 PM »
The correct answer is no.
But I just got out of my GN with the third pass on my intake gasket and my head gaskets, so what do I know?
Cavat: My intake is accurately machined as are my deck surface and head surface.
earlbrown
PSI: 6
Re: intake gasket
September 14 2016, 10:40:08 PM »
That being said, if you're using the intake gasket that's called for a GN toss it and get an older one. It's cheaper and not punched for EGR ports.
The 'wrong' gasket will keep exhaust energy from hitting the intake manifold (and trying to flex the piss-poor engineered block off plate if you have one of those)
Shimy87
PSI: 2
Re: intake gasket
September 15 2016, 09:21:28 AM »
Thank for the info!! I think I found one like you described, its on the way. Really thought I had enough RTV across the back last time....wont make that mistake twice
Last Edit: September 15 2016, 12:20:16 PM by Shimy87
earlbrown
PSI: 6
Re: intake gasket
Reply #5 on:
September 16 2016, 02:44:02 PM »
Depending the gap it depends on what I use. If the gap is huge I used the rubber gasket and Yamabond as sealant.
If the gap is smaller I toss the rubber and use a beat of The Right Stuff. The main trick is to set the intake STRAIGHT down into place without any sliding around.
Oh, and sometimes, but not that often I'll take a razor blade to the rubber gasket and shave that 'bead' off the top. That way it doesn't squish and deform the rubber more than it should and it increases the amount of surface area for the sealant to work.
intake gasket
