Powerlogger
Pages:
5
6
7
Topic: Powerlogger (Read 23433 times)
Scoobum
Re: Powerlogger
Reply #90 on:
October 10 2016, 09:28:09 PM »
Okay. I assume that's a 255/60/15 tire. I plugged the info into the Wallace Racing Calculator...a
nd the slip for that convertor is 17.9 percent.
Shimy87
PSI: 2
Re: Powerlogger
Reply #91 on:
October 10 2016, 09:39:19 PM »
I run 17 inch wheel so its a 275/40/17 nitto nt50r thats 26 3/16 tall. Your way past my understanding.
...is 17.9 % good , average or bad?
Scoobum
Re: Powerlogger
Reply #92 on:
October 10 2016, 09:52:44 PM »
The circumference for that tire is 83 inches. Plugging in the new data the slip checks in at 13.9 percent. Not bad for an unlocked convertor.
I'd try 1-2 pounds more boost...and see if it picks up on the top end charge.
Think of convertor slip as a clutch slipping on a standard trans. It's not putting all the power to the back wheels.
Last Edit: October 10 2016, 09:57:09 PM by Scoobum
Shimy87
PSI: 2
Re: Powerlogger
Reply #93 on:
October 10 2016, 10:15:22 PM »
Ill give it a try....thanks!!!
Shimy87
PSI: 2
Re: Powerlogger
Reply #94 on:
October 15 2016, 07:27:27 PM »
update on my slow top end. Did a compression test Pass side from front to back, 152,155,155, drivers side front to back 140,143,130. Test was done cold. Obviously I have a compression issue on drivers side. Should have done the head gasket on that side also when I had it apart just to know its good. Now don't know what to do. Maybe winter project, pull motor and rebuild??
TexasT
Legend in my own mind
PSI: 1
So, This black car is fast?
Re: Powerlogger
Reply #95 on:
October 15 2016, 09:45:21 PM »
Put a squirt or two of oil in each as you test and do the test again. Might tell if it is rings or the valves.
I don't think 130psi is too awfully bad. Is is within 20%.
gusszgs
Turbo Street Modified
PSI: 1
Limited quick brick
Re: Powerlogger
Reply #96 on:
October 15 2016, 09:50:47 PM »
Shimy, do it warmed up too
Jim
1987 T Limited
Shimy87
PSI: 2
Re: Powerlogger
Reply #97 on:
October 15 2016, 10:34:47 PM »
Wasn't really concerned about actual number as much as variation between cylinders. The pass side with the new head gasket is good, the drivers side is not, and the cylinder with 130 is 25 under the pass side. If it was within 10% I'd live with it. But 25 lbs. low is a lot, and I still get a hint of oil out that side valve cover breather. That low cylinder also had a piece of the sparkplug porcelain chipped off by electrode. I think the smart move is to pull that head and see whats up. I hope piston and rings are ok and maybe a new head gasket will solve the problem??
Shimy87
PSI: 2
Re: Powerlogger
Reply #98 on:
October 30 2016, 03:11:26 PM »
Had a chance to wrench a little. Pulled the rockers to close valves and put some air to the lowest cylinder. Got the stethhose out and listened in the intake, exhaust and dipstick tube. I hear no hiss in intake, clear hiss in tail pipe and unfortunately hissing also in dipstick tube. Had to quit but pretty bummed, was really hoping not to hear any hiss in the dipstick tube
Shimy87
PSI: 2
Re: Powerlogger
Reply #99 on:
November 11 2016, 10:44:08 AM »
update, pulled it apart yesterday and taking heads in for valve job. In listening with scope, I put air to the lowest cylinder and it is really leaking out the exhaust port. I also listened in the crankcase and then put air to the "best" cylinder and listened to the crankcase and the air sound was exactly the same. I'm hopeful that doing the valves brings compression back to within 10% varience.
Pages:
5
6
7
Powerlogger
