Shimy...send Eric the files...get his 2 cents. Post in the chip section on the other board. Calling Eric Marshall...pos t your logs. You'll get a quick response. I think Razor has the alky come on at 6 PSI default...and I assume you have the blue knob on 7...and haven't messed with the defaults in the PAC controller.Weak alky pump...that's a possible culprit.For shits and giggles...ask Eric how far the 37's and alky will take you.
Quote from: Scoobum on September 14 2016, 06:19:18 PMShimy...send Eric the files...get his 2 cents. Post in the chip section on the other board. Calling Eric Marshall...pos t your logs. You'll get a quick response. I think Razor has the alky come on at 6 PSI default...and I assume you have the blue knob on 7...and haven't messed with the defaults in the PAC controller.Weak alky pump...that's a possible culprit.For shits and giggles...ask Eric how far the 37's and alky will take you.37 lb injectors are good for around 400 HP without additional fuel. IDC*Injector Size*Cylinders/BSFCI use .55 for BSFC for a Turbo buick.
