Author Topic: DR Tire Pressure For Tonite?  (Read 7738 times)
« on: September 02 2016, 12:46:09 PM »
MAY leave the DR's on it for tonite...curre ntly too lazy to change the slicks/rims over...lol!. Temp tonite is 68 degrees and 64 percent humiditly and sunny skies. Track prep...will be a coin toss. PSI? RPM to leave at? Temp and humidity is better...so I'm just checking on high gear fueling tonite anyway.
MT 28 inch DR's mounted on correct 8 inch rims.
« Reply #1 on: September 02 2016, 01:06:22 PM »
I always started at 18 if they spun I dropped a pound or 2 never went lower than 15
Mobile larrym
Offline gusszgs
  • Limited quick brick
Re: DR Tire Pressure For Tonite?
« Reply #2 on: September 02 2016, 01:42:14 PM »
My 255's seemed the same 22 as at 16 not much difference.
What DR are you running Larry? MT's?
Jim
1987 T Limited
« Reply #3 on: September 02 2016, 02:27:41 PM »
Nittos now mostly for the street. Have run MTs I approached them the same way. If it's an all out race weekend I got 9" slicks.
Mobile larrym
« Reply #4 on: September 02 2016, 06:28:49 PM »
Brad I had my best launch at 16 psi.
