Author Topic: How much sence does this make? PL screengrabs inside.  (Read 5552 times)
Re: How much sence does this make? PL screengrabs inside.
« Reply #15 on: August 23 2016, 08:26:52 PM »
We're trying to keep you away from the porn...
You could reallocate that effort into creating cold fusion...
  It would take less time and much much less effort.  :)
« Reply #16 on: August 23 2016, 09:00:21 PM »
Julio got a hold of me...everythin g is in order.
I got rid of the camaro and bought a toy Miata.  I have stuff to do to it as well as the challenger and both buicks.  I can keep busy any time I want to...wanting to is getting to be the sticky point
Every days goes by I lose more ambition and enthusiasm. I've parked the GN and enjoy the Rebel tons more.
« Last Edit: August 23 2016, 09:06:18 PM by Pyro6 »
Offline aminga
  • Chicks Dig the Power Bulge
« Reply #17 on: August 27 2016, 11:53:49 AM »
If you're comparing spark advance in PL then it's only reporting commanded timing.  True timing is spark advance - KR.
