nothing to do with the damn pistons. Get a TT chip and set the timing at 18 degs in all gears. Simplify the hell out of it. Be sure you don't have an injector that is not working right.Not sure what size of injectors you have but to make it even more simple go to an SD chip and open loop it
Quote from: Steve Wood on August 21 2016, 10:56:08 AMnothing to do with the damn pistons. Get a TT chip and set the timing at 18 degs in all gears. Simplify the hell out of it. Be sure you don't have an injector that is not working right.Not sure what size of injectors you have but to make it even more simple go to an SD chip and open loop itBrand new tank, new sock, supra pump, 60's that are fresh off Chucks flow bench.the basics are covered and them some.
Mike, I assUmed I would be given the benefit of the doubt as far as fueling and ignition and the sort.Brand new tank, supra pump set to the correct depth, 60's freshly cleaned by Chuck, new hoses that don't leak, ported hoses, blah blah blah...
I didn't make the effort for that per se. Don't give m too much credit. I made pistons that didn't exist because I needed them for my build.
