The Bastard Child Buick Board
you use thread sealant on the end that screws in the block. You use the thread lubricant on the end that the nut screws on to and yes, you use the lube on the washer and nut bottomSo, do people use thread lubricant and torque the head down to 80 or is that if you use oil instead of the lube....? I think most go 80 with the lube but I am not sure about that
