Author Topic: Type 2 Ignition-Pics-Questions  (Read 9742 times)
Re: Type 2 Ignition-Pics-Questions
« Reply #15 on: July 31 2016, 08:19:47 PM »
But it gets there thru the stock wiring which is quite small in gauge.  If the weakness of Type lI is the single feed, then using a larger gauge wire straight from the alternator to the module via a hot wire will provide both more current and voltage to the module allowing it to deliver all it can
« Reply #16 on: July 31 2016, 08:59:54 PM »
If I look through my Buick junk I think I have a Caspers ignition module plug-n-play hot wire kit. Injectors and pump are hotwired...one more item won't hurt. :)
« Reply #17 on: August 01 2016, 01:49:17 AM »
The coils in that colour are aftermarket, aren't they? I have black originals ones that seem to work fine.
« Reply #18 on: August 01 2016, 08:37:33 PM »
Aftermarket of some sort.
Offline aminga
  • Chicks Dig the Power Bulge
« Reply #19 on: August 04 2016, 09:48:19 AM »
Here.
http://www.gnttype.org/techarea/ignition/module.html
There are 2 IGN feeds to the 85-87 type system.  One to the coils, one to the module (That's why you can't use a 2 step on an 84-85 type IGN setup even though it looks the same), both are pink/black which is just the switched power source through the system.  It's IGN power.
FWIW: They type 2 ignition produces a hotter spark but has a shorter dwell.
Offline gusszgs
  • Limited quick brick
« Reply #20 on: August 04 2016, 11:28:03 AM »
Brad I have a top quality dwell meter by Equis if you need to borrow  :)
Jim
1987 T Limited
Offline quick72toy
« Reply #21 on: August 13 2016, 05:39:23 PM »
I have run the type II setup off and on for years.
Yes, I hot wired the power with a relay off the alternator.
FWIW:
  The coils off a 97 (and up) Pontiac Bonneville SSEI are hotter than regular coils.
1991-1993 Chevrolet Lumina - AC Delco Ignition Coil D546   GM # 1106008
3.1L Vin T & W (Flex fuel)
L36 coil uses Delco part # D555
L67 coil uses Delco part # D576
BUICK PARK AVENUE (1999 – 2000)
BUICK PARK AVENUE ULTRA (1996 – 2005)
BUICK REGAL (1999 – 2000)
BUICK REGAL GS (1997 – 2004)
BUICK RIVIERA (1996 – 1999)
CHEVROLET IMPALA SS (2004 – 2005)
CHEVROLET MONTE CARLO SS( 2004 – 2005)
OLDSMOBILE LSS (1996 – 1999)
PONTIAC BONNEVILLE (1999 – 2003)
PONTIAC BONNEVILLE SSE (1996 – 1998)
PONTIAC GRAND PRIX (1999 – 2004)
PONTIAC GRAND PRIX GT (2006 – 2007)
PONTIAC GRAND PRIX GTP (1997 - 2005)
Series II L67 coils, or the red MSD ones
 The 97 and newer L67 coils are hotter than the other GM coils, and only slightly 'cooler' than the MSD's. 8224
blue stripe on the bottom
91.5 PA Ultra w/L67 got Delco. And 92 L27 depended on production date.
92-96 SSEi coils and the 92-current production NA coils are weaker than the 97+ SC coils,
L67 Supercharged
This engine is or was used in the following cars:
1996-2005 Buick Park Avenue Ultra
1997.5-2004 Buick Regal GS
1996-1999 Buick Riviera (optional 1996-97, std. 1998-99)
2004-2005 Chevrolet Impala SS
2004-2005 Chevrolet Monte Carlo SS
1996-2004 Holden Commodore (VS, VT, VX, VY)
2001-2004 Holden Monaro
1996-1999 Oldsmobile Eighty-Eight LSS (limited)
1996-2003 Pontiac Bonneville SSEi
1997-2003 Pontiac Grand Prix GTP
Cheers
Paul
1972 Toyota Celica  87 TR drive train
Motor 30 over, 10/10 crank, HV.oil pump, P&P heads, PTE 44, Hot wired GSS 340, 52lb Siemens, mod ECM, Speedpro 204/214, Dutweiller big neck intercooler, 62 mm TB, Power Plate, Hot wired coilpack    AC CR42’s, Postons headers, MAFTPro,  LC1 WB O2 sensor, Alky kit
« Reply #22 on: August 13 2016, 06:17:52 PM »
Thanks for the info Paul. Testing this stock NA module under race conditons tomorrow.
« Reply #23 on: August 13 2016, 09:55:08 PM »
Left me confused, Paul.  Not hard to do, I know.  :)
So, are you suggesting that the MSD 8224 is the hottest of them all and the L67 supercharged coil is almost as hot making those two the top choices? And the L67 is Delco D576?
And, I assume you have had good luck running the Type II? And are you, or have you, run the D576?
Thanks for providing the info!
Offline quick72toy
« Reply #24 on: August 16 2016, 10:21:57 PM »
Good luck!  :rock:
Offline quick72toy
« Reply #25 on: August 16 2016, 10:45:23 PM »
Sorry for the confusion Steve, and you are not alone there. I confuse myself constantly LOL. It was really debatable whether the MSD's were any better than the L67's. But yes, those were the two top choices. and yes, the L67 is the D576.
I have a lot in the past, and for some strange reason, ( I don't really remember why) I switched back. I am in the process of switching back now after suffering some bad misfiring. Strange thing is that the Magnavox Module and coil pack checked out fine with Caspers coil pack tester. (Plugs are new, wires are Magnacor. Need to check the resistance on them) I actually made a simple setup that allows me to run Caspers tester on the Type II setup, and you can see a slight difference in the performance between the two ignition types.
FWIW I had actually tried the GM 3800 Fast start setup, (when Bruce P was around. RIP) and yes, it did start super quick, but there was a misprint in one of the wiring diagrams I had got, and that caused some issues. I pulled everything off the car and went back to stock in frustration. I later found the correct wiring diagram, but just didn't want to go through the hassle of putting it all back together again. I will probably try it again now that the bad taste has gone.
My pleasure Steve. Just trying to share.
