Author Topic: Ignition Module Pic-Please Look  (Read 11798 times)
Offline 626gn
Re: Ignition Module Pic-Please Look
« Reply #30 on: July 26 2017, 05:44:13 AM »
Wells often has a very bad reputation for this kinda stuff.  I would stick to Delco or Standard, myself
^^^ This. AC Delco 24503624 module is what you need. Works very well.
’87 Limited – Stock short block, 206/206 billet roller, ported irons, TE45a, FMIC, ATR DP, ATR exhaust, double pumpers, 80lb injectors, TurboTweak AXiS, LS1 MAF, Janis transmission, 9”AC 16930 NL, Alradco dual fans, Eaton posi, Moser axles, ATR sway bar, Kirban seat braces.
« Reply #31 on: July 26 2017, 07:04:17 AM »
The AC is triple the price up here.
« Reply #32 on: July 26 2017, 11:15:37 AM »
And that is if you know someone! :(
Offline 626gn
« Reply #33 on: July 28 2017, 01:08:30 PM »
I see... Well if you get desperate let me know. I got a couple extra here.
« Reply #34 on: July 28 2017, 01:14:05 PM »
Thanks so much!
« Reply #35 on: July 28 2017, 04:18:48 PM »
I talked to Julio from Razors alky a while back when he called about some oil pump info.   He told me that he buys the $19 ECMs off Ebay and has perfect success with them.   Only 'issue' is that aftermarket tachs don't work all of the time.
« Reply #36 on: July 28 2017, 04:57:21 PM »
Neither does Caspers coil tester
