Author Topic: Check Valve-Pic Inside  (Read 4190 times)
« on: July 26 2016, 09:37:32 PM »
I removed the charcoal canister a few weeks back...but forgot I had an ATR relocation kit. I installed it...but forgot about this check valve. The black end has vacuum stamped on it...so I assume this goes to the engine side to burn any vapours/fuel from the cansiter.
Re: Check Valve-Pic Inside
« Reply #1 on: July 26 2016, 10:18:57 PM »
I think your right :rock:
« Reply #2 on: July 27 2016, 12:18:55 AM »
« Reply #3 on: July 27 2016, 12:19:49 AM »
always good to check them to see if they still work...suck on the engine side but not able to blow thru it from the engine side
« Reply #4 on: July 27 2016, 05:23:19 PM »
Still working. :)
Offline GavinHunyady
« Reply #5 on: July 28 2016, 11:54:42 AM »
yum.... hydrocarbons.  :atbeer:
« Reply #6 on: August 01 2016, 02:18:22 AM »
Just put it in your mouth and suck.
(man,if I had a dime for every time I said that)
If it works, air will only go one way.  If if goes both ways (like many new 'lesbians' I know0 then it's shot and need to be replaced.
Offline Be4u
« Reply #7 on: August 01 2016, 04:36:30 AM »
I :049: Earl.
Save the bumper fillers!
Move to Canadia!
