Author Topic: Attention Fuel Pump Installers  (Read 20266 times)
Re: Attention Fuel Pump Installers
« Reply #15 on: July 26 2016, 10:14:07 PM »
What size pump?
Offline tar baby
« Reply #16 on: July 26 2016, 10:18:27 PM »
255
Offline tar baby
« Reply #17 on: July 26 2016, 10:23:27 PM »
also I am running a hood mount auto meter Guage
« Reply #18 on: July 26 2016, 10:25:29 PM »
Were you able to get it down to 43-44 line off? I'll assume you're using Erics chip.
« Reply #19 on: July 27 2016, 12:04:54 AM »
Mine shot up to 60 after installing a 340 Walbro. Couldn't turn it down. Had a case of of the Saginaw fitting blues. Hadn't heard of one shooting up with a 255 but anything is possible.  That first pic that brad posted showing where to cut the little vent window may be your solution or drilling out the Saginaw fitting to allow an increased volume of fuel to return to the tank.  Have you tried just adjusting the regulator to lower the pressure?
Offline tar baby
« Reply #20 on: July 27 2016, 05:24:17 AM »
I cut the rubber . adjusted the regulator . yes new chip and injectors.
Offline tar baby
« Reply #21 on: July 27 2016, 09:34:48 AM »
I'll post my scan master numbers when I get home ..
« Reply #22 on: July 27 2016, 12:02:18 PM »
I wonder how much restriction the vapor return line in the sender would create?
« Reply #23 on: July 27 2016, 05:27:15 PM »
Tar Babys name is Dan...and he lives about an hour north of me. Dan...fill the guys in on your build. Last time I dropped by the car was stripped.
Offline tar baby
« Reply #24 on: July 27 2016, 07:37:34 PM »
well I took a 84 grand national apart and put it back together..  with an 87 intercooled engine . tried my hand at painting .. its a twenty footer ..lol but its altogether.. and now I'm chasing little problems like this fuel pressure issue ...
« Reply #25 on: July 27 2016, 07:44:07 PM »
Was the fuel pressure normal with the old pump?
Offline tar baby
« Reply #26 on: July 27 2016, 07:44:15 PM »
iac 79-81
tps .50
af 07
lb 46
batt 13.6
int 124
bl 118-128
clt 180-200
ats 109
rpm 850
o2's 700-718
« Reply #27 on: July 27 2016, 07:48:11 PM »
TPS should be 42 and the IAC should be 10-20. BLM should be steady at idle...not fluctuating. Steve has the writeup on his site to adjust the IAC and TPS.
Offline tar baby
« Reply #28 on: July 27 2016, 08:28:46 PM »
ok ill adjust them . but yes pressure was steady 43 pounds with old pump and injectors..
« Reply #29 on: July 27 2016, 09:31:18 PM »
sure sounds to me like you crossed the vapor return line with the fuel return line if you used a 255 pump
