Author Topic: Dieing In High Gear-Opinions Wanted  (Read 15339 times)
Offline 626gn
Re: Dieing In High Gear-Opinions Wanted
« Reply #60 on: July 30 2016, 12:22:43 PM »
1st pass-Left from an idle and waited till it went into 3rd gear...then flat footed it. Revved clean in 3rd gear.
2nd pass-Left from an idle and waited till it went into 2nd gear...then flat footed it through 2nd and 3rd. Revved clean in 2nd and 3rd.
3rd pass-Brought the revs up to 1500 and jumped on it. Made a clean pass through the 1/8th mile. On 17 PSI with Erics chip on the default settings it went 8.40 at 84 through the 1/8th...and coasted from the 1/8th to a 13.8 at 76. High and low gear 02's were in the 850's. I used the other Delco module...seems to work fine.
Thanks for everyones help...always appreciative.
:cheers:
’87 Limited – Stock short block, 206/206 billet roller, ported irons, TE45a, FMIC, ATR DP, ATR exhaust, double pumpers, 80lb injectors, TurboTweak AXiS, LS1 MAF, Janis transmission, 9”AC 16930 NL, Alradco dual fans, Eaton posi, Moser axles, ATR sway bar, Kirban seat braces.
