Dieing In High Gear-Opinions Wanted
Pages:
2
3
4
5
Topic: Dieing In High Gear-Opinions Wanted (Read 15340 times)
Re: Dieing In High Gear-Opinions Wanted
Reply #15 on:
July 16 2016, 07:49:27 PM »
624 is the original delco number and the only module that will work with caspers coil/module tester. the other one, when I google it, comes up for 3.8 and not the turbo...did not find it on rock auto. The original was made by Magnavox
Seems to be for a 92 olds 3.8 I bet it will not work under boost
the Standard brand LX338 reportedly works for some. None of the other brands seem to work. Delco #19260720 is the GM replacement for 624. It will not work on the casper coil tester so it is made differently...
probably by Standard or someone but I have heard of it working
Doesn't Dan or someone have a known working module and coil so you can find out if that is the problem.
Scoobum
Reply #16 on:
July 16 2016, 08:02:14 PM »
Once again Steve...parts are scarce up here. Modules up here...cost an arm and a leg brand new. Is there an aftermarket brand that you know for sure works that I can get through a jobber. If so...which one(s).
Reply #17 on:
July 16 2016, 09:02:39 PM »
The Standard LX338 has worked for quite a few people....
Still, I would try to prove that was the problem before I bought anything
TexasT
Legend in my own mind
PSI: 1
So, This black car is fast?
Reply #18 on:
July 16 2016, 09:31:00 PM »
I believe the AC Delco D1996 will work, but they aren't much less expensive
Reply #19 on:
July 16 2016, 09:55:53 PM »
That is the one mentioned above
. 720 last three numbers
TexasT
PSI: 1
Reply #20 on:
July 16 2016, 10:16:02 PM »
yes but in a delco number
Scoobum
Reply #21 on:
July 17 2016, 09:22:08 AM »
If I have to shell out for a new module...then I'll walk into the dealer and order one. Lets talk about this fuel pump. When Dan and I went to fire this engine up...it took a little while for the pump to come up to line off pressure. I don't recall having to wait after an engine change before. Something else. The pump isn't holding pressure after key off. I noticed that yesterday. I don't have the FP hooked to PL. I always take a practice run down the track and watch the FP gauge to verify the fuel pressure is rising 1 for 1. When I eased into it Friday night, I let it go into high gear...but not WOT...and called it good...as the fuel pressure was following boost. I'm wondwering if it's starving for fuel at WOT. I can get a FP from Jack at Racetronix in a day or two. Everyones thots on this.
Reply #22 on:
July 17 2016, 09:41:42 AM »
Trust but verify....Rona
ld Reagan had a buick. Check it. Sounds fishy
gusszgs
Turbo Street Modified
PSI: 1
Limited quick brick
Reply #23 on:
July 17 2016, 11:44:38 AM »
What are the O2's doing
Jim
1987 T Limited
Scoobum
Reply #24 on:
July 17 2016, 12:53:22 PM »
Jim, I just checked the file. The instant it bogged...the 02's dropped horribly...all the way to zero for a split second. TPS shows me outta the throttle instantly. KR was less than 1 count. Boost is just shy of 16. I just barely pulled the rod over the arm for the test runs. Any ideas guys?
gusszgs
PSI: 1
Limited quick brick
Reply #25 on:
July 17 2016, 01:07:43 PM »
I read something about if you clamp the hose on the fp too tight or with 2 fuel inj clamps that can cause the "hold pressure" issue after shut off. Mine doesn't hold either, but never been an issue.
Check ball is in the snout I think.
Maybe the pump is taking a dump. And only showing up on extreme demand.
I'd verify like Steve said 1:1 in high gear.
Jim
1987 T Limited
Scoobum
Reply #26 on:
July 17 2016, 01:18:13 PM »
I'm gonna order a pump from Jack. I broke my own rule. I always install a new pump every spring.
Scoobum
Reply #27 on:
July 19 2016, 11:38:30 AM »
Anyone had any luck with the Standard LX338-T
It's readily available up here.
larrym
PSI: 1
Reply #28 on:
July 19 2016, 12:33:29 PM »
They are hit and miss Brad, will your supplier take it back if you have a problem its obvious if they are not right.
I tried 2 and the 3rd one was good.
Scoobum
Reply #29 on:
July 19 2016, 02:03:13 PM »
Trying the fuel pump first. I have 3 modules here I can try after I pop a fuel pump in it.
Pages:
2
3
4
5
