Author Topic: Dieing In High Gear-Opinions Wanted  (Read 15337 times)
« on: July 15 2016, 11:09:43 PM »
My car ran great tonite...excep t in high gear. It's acting like the engine is cutting out. Pulls like a freight train in 1st and 2nd...but falls on its face in high gear. SM numbers are normal...and the PL file looks fine. Fuel pressure is rising with boost...very slight KR...less than 1 count in high gear...prolly from sputtering. Partial throttle in high gear is fine...but falls on its face at WOT...in high gear. I'm thinking the ignition is breaking down under full load in high gear. I have a couple spare coil packs and ignition modules. Once again...open to suggestions.
« Reply #1 on: July 15 2016, 11:44:07 PM »
Good voltage on the log?
Re: Dieing In High Gear-Opinions Wanted
« Reply #2 on: July 15 2016, 11:54:41 PM »
Larry...good question. Laptop is in the car. I'll post it in the morning. I remember the SM at idle was in the 13's. I think it's normally 15.2 at WOT with the Caspers volt booster...but let me check in the morning.
« Reply #3 on: July 16 2016, 08:01:40 AM »
More PL data. Engine is cutting out at 4550 RPM's. Voltage at WOT is 15.6
« Reply #4 on: July 16 2016, 09:13:44 AM »
as it's the easiest thing I can think of, swap the module/coil :)
If that is a no go...then measure the crank thrust
« Reply #5 on: July 16 2016, 09:18:00 AM »
Steve...off the top of your head...do you know the ohm value for the coils. I'll check the ones on the car...and the spares I have.
« Reply #6 on: July 16 2016, 09:31:58 AM »
11-13,000 is the typical ohmage
« Reply #7 on: July 16 2016, 09:33:39 AM »
Thanks. :)
« Reply #8 on: July 16 2016, 01:38:24 PM »
Bear with me guys...cuz I can barely put batteries in a flashlite. I put the ohm meter on 20K...and this is what I got from the coil pack from last nite that's on the car.
11.58
11.53
11.61
I have 2 spare coil packs.
1st
12.53
12.58
12.58
2nd
11.53
11.52
11.53
I have 2 spare ignition modules...one with a part number...and one without. I'll post pics...maybe you guys can figure out what brand they are...and if they'll work with an external tach.
« Reply #9 on: July 16 2016, 02:53:44 PM »
coils look okay.  Does not say anything about the modules.
Tach should work fine with the modules...but they may, or may not, be anygood
« Reply #10 on: July 16 2016, 03:21:34 PM »
Pics of the modules.
« Reply #11 on: July 16 2016, 05:13:25 PM »
I swapped in one of the extra modules I have. We'll try it again on the 29th.
« Reply #12 on: July 16 2016, 05:26:03 PM »
pretty sure that delco one is for a regular 3.8-not a turbo
« Reply #13 on: July 16 2016, 05:30:22 PM »
Great...that was the one I swapped in. I just can't win. :cheers:
« Reply #14 on: July 16 2016, 07:29:28 PM »
Steve...the one I removed from the car looks like a Delco unit...and we have a different part number...so you're likely right.
24503624
  6136
The million dollar question. What's the difference...a nd will the one I installed work with our engines? If not...then I'll swap in the other spare I have.
The car fired right up with the one I installed.
